-   -   Torque spec for the intake runner nuts? (http://forums.pelicanparts.com/porsche-911-technical-forum/631076-torque-spec-intake-runner-nuts.html)
Hotwatermusic 09-22-2011 12:53 PM
I have my CIS re-installed on the engine and am about to bolt it down. Can anyone tell me the torque specs on the 2 nuts on each intake runner? I couldn't readily find it in the bentley or 101 projects book. Thanks!
DRACO A5OG 09-23-2011 12:04 AM
HWM,
Not familiar with an intake runner do you have a pic?
Jim
JJ 911SC 09-23-2011 02:32 AM
Since I'm not sure 100% the one you referring too... I wont give you the number in case we are not taking about the same.
But if its the one I'm thinking, check one of those page (they both give the same torque value):
Bentley 911SC page 102-39
Bentley 911 Carrera page 102-38
psalt 09-23-2011 03:17 AM
18 ft/lbs.
DRACO A5OG 09-23-2011 08:10 AM
Originally Posted by psalt (Post 6270362)
18 ft/lbs.
Is it me or is almost any fitment connected to the engine block is 18ft/lbs :confused:
cmonref 09-23-2011 08:42 AM
It's not you. 18 ft-lbs is the normal spec for 8mm bolts/studs. Don't try it with 6mm fitments to the engine CASE.
Hotwatermusic 09-23-2011 01:01 PM
Originally Posted by DRACO A5OG (Post 6270301)
HWM,
Jim
The six aluminum tubes that run from the CIS airbox to the intake valves. They house the fuel injectors. I call them intake runners. I don't know what their technical term is.... They're bolted to the engine with 2 nuts each.
JJ 911SC 09-23-2011 02:10 PM
Intake Manifold
25 Nm (18 ft-lb) as found in Bentley 911SC page 102-39
NotoriousDAN 04-23-2012 07:22 PM
i know this threat is old but is there a particular sequence to follow? Work inside to out side?
JJ 911SC 04-23-2012 07:36 PM
Not that old...
Both side are independent from each other so you are left for 6 nuts in 2 rows on each side.
So I did front, rear and middle in torque steps; a run at 10, 15 and 18 ft-lb.
Bob Kontak 04-23-2012 07:39 PM
There are two nuts per runner. No special sequence but snug both nuts before final torquing.
