-   -   Problem adjusting fan (http://forums.pelicanparts.com/porsche-911-technical-forum/631226-problem-adjusting-fan.html)
flash951 09-23-2011 11:20 AM
My fan belt seems a little loose. Since I have problem with the engine running hot I thought it was a good idea to tight-up the pulley. I found that there was non spacers left on the inside, with other words I can not tighten it. It was 3 spacers on the outside, beneath the bolt.
Any ideas? Wat is wrong?
redstrosekNic 09-23-2011 11:28 AM
I don't think you have all of your spacers. I believe that there are supposed to be 6. Someone will correct me if I'm wrong.
Good luck!
Flat Six 09-23-2011 11:32 AM
Belt is likely stretched beyond adjustment. With zero washers between pulley halves, you should then have all six washers on the outside under the pulley nut.
It's possible that not having all 6 washers under the pulley nut allows your pulley halves to wobble/separate, also contributing to belt slippage. Either way, get more washers so you have a total of 6. Belts are so inexpensive you should just replace. And if you're unsure how old the current belt is you should replace. You've already spent more time and effort trying to tighten this thing, now posting on PParts forum than -- probably already cost you more than the purchase price of a new belt.
Good luck
86 911 Targa 09-23-2011 11:41 AM
Here's how it works:
http://forums.pelicanparts.com/uploa...1316806780.jpg
http://forums.pelicanparts.com/uploa...1316806797.jpg
And, as per the above post, all six shims must be mounted either between the pulley halves or under the cup.
Good luck,
Gerry
flash951 09-23-2011 12:46 PM
Thanks, I try with a new fan belt then, and all 6 shims in place as a starting point.
dshepp806 09-23-2011 01:37 PM
Gotta' have all six, for sure...BEST!
Doyle
KNS 09-23-2011 02:36 PM
When I bought my 84 the belt was really tight, someone had put on the wrong size belt...
dshepp806 09-23-2011 03:01 PM
Very easy to much up a shaft/bearings.......bad tension, so to speak.
Best!
Doyle
flash951 09-28-2011 01:45 PM
I know have all the shims and a new fan belt.
I've placed 5 shims in between and 1 shims outside.
The fan belt is now actually to tight, maybe?
How tight should it be?
By the way, my old fan belt looked like an unoriginal "mc" belt.
My new fan belt is the 710 mm original "NARROW V-BELT" I belive.
My fan number is: 901 106 101 5R
Is this the correct belt?
86 911 Targa 09-28-2011 01:54 PM
Belt.
The porshe belts are marked 710 X 9.5 mm.
Five in the middle sounds like a 10mm belt.
If you push on the belt with your thumb it should deflect about 1/2 inch.
Also, be very certain about the pulley halves alignment.
flash951 09-28-2011 02:31 PM
Push gently? I am able to push 1/2 inch or rotate 1/2 turn, but with a little pressure on my thumb.
I think I have the 10 mm. Is it wrong?
Part number: 99919217650
The pulley halves alignment are a few mm off, I have to have less shims between to push it into perfect alignment, there is like a gap.
86 911 Targa 09-28-2011 03:53 PM
Alternator Belt.
Here's what I found on the Pelican site.
You have the correct belt.
Re-check the pulley halves alignment.
http://forums.pelicanparts.com/uploa...1317253991.jpg
http://forums.pelicanparts.com/uploa...1317254006.jpg
flash951 09-28-2011 04:48 PM
Seems like the 9.5mm x 710mm is also correct for my -75 2.7L engine.
The pulley halves alignment is straight but the holes doesn't align 100%.
I have to have less shims in between to align the holes perfectly.
Only then is it possible to have the "nut" go far enough in to be able to "twist" the nut the 2mm to the left to align it 100% with the holes on the other half.
flash951 09-29-2011 02:21 AM
Have the 9.5mm in order now, I hope the tension will be ok with this one.
Driver_X 09-29-2011 03:44 AM
If the holes don't align, then your pulley 1/2 is likely damaged from running without the proper # of shims. Ask me how I know: http://forums.pelicanparts.com/porsche-911-technical-forum/610056-pulley-alignment-question.html
More info: http://forums.pelicanparts.com/porsche-911-technical-forum/232018-pulley-shims-wrong-config.html
Jerome74911S 09-29-2011 06:49 AM
If your pulley halves have wear similar to what is seen in these pictures, then that wear can cause the misalignment that I think you mention.
If you have such wear, repair will be necessary.
http://forums.pelicanparts.com/uploa...1317307659.jpg
http://forums.pelicanparts.com/uploa...1317307725.jpg
flash951 10-03-2011 04:09 PM
I think I have similar wear on mine. What kind of repair? Buy a new pulley halve? Expensive? I now got the 9.5 mm belt and used 5 shims in between, it is still a little to tight.
Jerome74911S 10-03-2011 04:30 PM
The outer half of the pulley shown I replaced. The inner half with the notch in the "drive cog" (I forget the proper name of the thing) I had welded up, then ground to proper original shape. It seems to work fine with no problems.
The cost for the welding and reshaping was only $15 or $20.
Some have said the repair could have been made using J-B Weld, but my experience suggests that J-B does not hold up. A little welding will do it.
