engine 3.6 in carrera 3.2 whit 915 trans suggestions (flywhell)
hi, i'am danilo from italy, i like to fit the 3.6 engine on 3.2 body whit 915/72 trans, i have:
-3.6 engine (C4)
-3.6 fly(dual..not good i suppose) + clutch 240mm
-915 trans
questions:
-if possible fit the 240 cluth? (or on 915 accept ONLY 225?)
-what flywheel is god for this convertion? (rs? aftermarket?)
thanks!Grazie!
---the difference between insanity and genius is success--
Old 11-02-2011, 03:55 AM
RETIRED
Joe Bob's Avatar
More than a couple of threads on this.
Depending on machine shops or DIY ability.....you use a 3.2 flywheel for a 915. Take the center of the 3.6 and graft it on the 3.2 flywheel.
A couple of US companies make conversions flywheels and can machine a larger clutch face. I've used Kennedy Engineered Products (Palmdale CA) for many years.
KEP also supplies the clutch TO and PP.
2012 ML350 3.0 Turbo Diesel
Old 11-02-2011, 04:50 AM
