Checking LSD When Trans is Out of Car
Hi,
Can I check the 915 LSD by spinning the shaft inputs when the box is out of the car? Thanks for any help. James |
Look for roughly 15 Ft pounds to slip the clutches.
Mark www.exotechpower.com 1981 Targa-messed with. 91 C2 supercharged track rat Radical Prosport-irritates the GT3 guys 40 years of rebuilding services |
gearhead
According to Porsche's own published service manual, for a 40% configuration the working range is 30-57ft/lbs. For an 80% race configuration that goes up to 43-85ft/lbs. When it drops below the minimum number it's time to rebuild.
Regards, Matt
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 |
OK. I have a silly question, if the transmission is just sitting on the floor, how do I check with my torque wrench?
Thanks. |
Just lock one drive flange and turn the other. Matts numbers are workable for new rebuilds but assuming this is a stock/street car you can survive with less.
I assume that there is a nut to put a socket on?
gearhead
And I don't recommend ever testing it on that drive flange bolt. That bolt is only rated to around 45ft/lbs. If you have a diff that tests higher, you can break the bolt or damage your LSD. What you need to do if you are going to test it is make a tool that spans the flange (some square bar stock with a bolt welded to it is the best replica of the factory tool) that you can put a torque wrench on. You install a couple of used CV bolts into the flange and brace it off the tool. Then you toss the CV bolts in the bin when you are done and don't reuse them on the car.
1974 914 Bumble Bee 2009 Outback XT 2008 Cayman S shop test Mule 1996 WRX V-limited 450/1000 Last edited by Matt Monson; 09-27-2011 at 10:43 AM.. |
This is more complicated that I had hoped. Is there another visual confirmation? I understand that the stamped numbers are unreliable.
gearhead
Are you trying to determine whether or not it has an LSD or are you trying to determine whether or not it's worn out?
If you just want to know if it has an LSD, spin one flange and look which way the other one spins. Same way it's an LSD. Opposite direction it's open.
Yes, also determine if it is working. I imagine that most of these are getting tired.
Thanks for everyones help!
