Question about window washer nozzles
How do you clean these? Mine are clogged up with car wax from the PO. They put out fluid, but not as much as they should. Thanks in advance.
Old 03-19-2002, 05:58 AM
A simple tool...
Drop by a music store and pick up a set of cheap guitar strings... $5 - Cut the strings to desired length - at the "ball end"
There you have it - multiple sizes of perfect tools for the job. Use the ball end as a little handle. It works well....
Jim
Old 03-19-2002, 06:06 AM
Thanks guy. I didn't know if there was something that I could soak them in to dissolve the wax. I had used a sewing needle and it improved the spray a lot. But it still doesn't spray as much as it should. I will try your suggestion and let you know how it goes.
Old 03-19-2002, 07:46 AM
pwd72s's Avatar
I just used a pin...after I clogged them with wax, but my wrinkle was to have Cindy in the car, squirting them as I used the pin...oh, I took the wipers off before doing the deed...but the force of the spray shoved the old wax right outathere.
Old 03-19-2002, 09:30 AM
That's a good one! Oh honey...
Old 03-19-2002, 11:04 AM
