-   -   Build numbers ? What do they tell ? (http://forums.pelicanparts.com/porsche-911-technical-forum/631802-build-numbers-what-do-they-tell.html)
prebordao 09-27-2011 05:38 AM
A few years ago while stripping the body for a rebuild, I noticed some numbers written in chalk or wax, on top of the instrument panel.
I don't have'em here but I think they were like XXX-XXXX.
I suppose it's a build number, can I get some information from there, build date ?
fryardds 09-27-2011 02:53 PM
Are you asking about the significance of this number for your '74 Targa? The seven digit # on the top of the dash is the same # stamped on the passenger side lower dash, under neath the knee pad.
The # for a car built after '68 is not the same as the VIN. The prior years this # is the same as the VIN. The build, or production # for your '74 Targa would be 114XXXX. The '1' is for a production body (a '0' is for a replacement body)' the next '1' is for a Targa (a '0' is coupe)' '4' is "74. The last 4 digits are sequential as they were built. Only Porsche records will match a build number with a VIN.
Dash Serial Number
prebordao 09-27-2011 03:20 PM
Thanks. Yes, I was asking for my '74, the number is 114-1416 so it "fits".
The stamping under the dash also applies post 68 ?
fryardds 09-27-2011 07:34 PM
Yes, the stamped # on the lower dash is the same as the wax pencil # on the top of the dash. I am curious, is your Targa an early production model for '74? Maybe even produced in '73?
prebordao 09-27-2011 11:57 PM
Yes, one of the earliest. Built in oct or nov 73.
