redridge's Avatar
Carrera Exhaust Tip Removal?
My black exhaust tip is beat up.... I want to switch to chrome to match the new chrome H4's I got.... anyone know the best way to take out the tip w/o butchering it? TIA
Old 09-27-2011, 01:23 PM
Oh Haha's Avatar
I believe all of the factory tips on 74-89 911s are crimped on. I doubt you'll be able to remove it cleanly as it is designed to NOT slip over the end of the "inside" pipe.
My stock tip was beat and the only way it was coming off was to cut it along the side and then peel it off.
Pacific Blue
Wayne
Old 09-27-2011, 01:31 PM
Goldfinger
Mattcamp's Avatar
+1 Tearing it off with vice-grips works too. Getting it started is the tough part.
1984-Carrera (pewter metallic)
Old 09-27-2011, 01:33 PM
redridge's Avatar
so, does the tip slip over the outside and inside of the exhaust pipe?... its really hard to tell where the tip ends.
Old 09-27-2011, 01:41 PM
Oh Haha's Avatar
The tip itself slides over the end of the pipe coming out of the muffler body. A new one would need to be tapped gently over that pipe and then dimpled to keep it stationary.
I went with an aftermarket tip so I have no first hand experience with re-installing a stock style tip.
Here's a link to a factory muffler which shows the tip clearly.
OE muffler near new '78-89 $100
Pacific Blue
Wayne
Old 09-27-2011, 01:47 PM
gshiwota's Avatar
I used a small dremel cut off tool and cut it off. Mine was pretty chewed up so it wasn't going to slide off easily. The dremel worked great and was off in a few minutes.
Old 09-27-2011, 01:57 PM
1986911's Avatar
I used an air chisel\hammer with some PB Blaster and it came off "like Butta"
MG---1986 911 TARGA, SSI'S, STEVE WONG CHIP, M&K EXHAUST, ELEPHANT RACING GOODIES + TRU DESIGN CUSTOM FUCHS
1989 930 FACTORY SLANT NOSE -- RARLYL8 EXHAUST, K27 7200, TIAL 46MM, 0.9 BAR SPRING, GARRETSON INTERCOOLER , LEASK WUR, WEGO IV AFM AND NHS BOOST GAUGE.
2012 DODGE RAM 3500 LONGHORN 4X4 "EVERYTHING BUT THE KITCHEN SINK"
Old 09-27-2011, 05:11 PM
