MSD 6AL-2 ignition upgrade
I was wondering if any members out there have installed the MSD 6AL-2 ignition system on their 3.0L CIS engines? How much did it improve performance overall?....worth it? I have an '80SC with BAE Turbo and was wondering if I should perform the upgrade? Would it be at all possible to send me a PDF of the installation manual?.....much appreciated!
Alex |
THere are other threads on this subject, one only a few days ago. There will be no improvement in performance, unless of course your existing unit is defective. You may notice, I did, a slightly smoother motor below 3k. I think their website has the instructions in downloadable form.
One of the MSD wiring threads:
http://forums.pelicanparts.com/911-engine-rebuilding-forum/576337-msd-6al-how-wire.html |
FWIW I've had bad luck with the 6AL-2. went thru two that both crapped out at rather inconvenient times. went back to a 6AL, no issues.
I had an MSD in my 2002 that failed and cost me a race weekend. Not a fan.
Thank you gentlemen! Interesting...sounds like it's 50/50 with regards to the MSD upgrade. My engine idles just fine, however, my problem is at around 4000RPM+....lot's of hesitation and then surging when I come on boost. I thought having a programable system would allow me to tweak the advance/retard. How about the Perma-tune upgrade?...any comments would be greatly appreciated!
Alex |
Note that the MSD 6 AL 2 isn't programmable. It does have a rev limit switch. Perma-tune won't do anything but fix a not-properly-functioning stock unit. Not sure your problem has much to do with the CD unit.
Note that the MSD 6 AL 2 isn't programmable. It does have a rev limit switch. Perma-tune won't do anything but fix a not-properly-functioning stock unit. I know nothing of turbos but think I'd look elsewhere.
Instead of the "MSD" Brand Multi-Spark Discharge Unit, go with the Mallory HyFire VI-A version. Digital instead of analog and I've yet to have a box (out of the dozens I have installed) fail.
Aside from that note... You will notice the improvement at idle and across the whole RPM range if your CIS system is in good/great shape. BUT! The improvement is best felt when upgrading the coil, plugs and wires as well. |
the MSD is a very good unit. there are too many out there using them for it not to be. as for an upgrade from a bosch, it is not. but when my bosch crapped out, the MSD was a much cheaper alternative. daveE, anything can break or go bad. |
it will, the capacitor in your is bosch are very old.
