Tool for Removing Heat Exchanger Nuts
I got the left side heat exchanger off, but I'm having a bit of trouble with the right one.
All three barrel nuts are removed and I'm left with the three nuts. I have a bunch of wrenches/sockets, but nothing seems to give me the right access to try and turn the nuts. The engine case seems to get in the way. What do you guys use? Also, the engine is removed and on a stand. |
I have a set of 'distributor' wrenches. They worked. also craftsman swivel sockets. If you put a swivel on a socket its too long so you need the integrated kind. Also crowsfoot sockets and stubby box wrenches.
Make sure you know which nuts came off what studs. Mine were of two different sizes. IE for some I needed a 13 and for some a 12. Its a PITA, but you just need to find that special tool combo for each one. Oh, a sidewinder socket wrench helps to. That's the socket where you have a T handle and just turn the T and the socket spins. Its very useful other places as well like CV bolts and starter nuts. -Michael |
snap-on 3/8 drive, 13mm chrome wobbly socket and long extension. and oxy/acet heat on the nut first.
yup, I'm with John Walker, of course....I have some universal short sockets, snap on, in 12mm and 13mm, these will do it.....when you buy SSI's you get a 12mm bent closed end wrench.
All the above, although I never had much problem with a long offset boxed 13mm wrench.
Mine came from some tool kit from my 1st car back in the 80's. A Lada, the Russian version of the Fiat 124 :D:D:D Glad I keep the tool pouch :) BTW some of those copper nut comes in a 12mm version. |
Same +1 on the 6pt swivel socket. Like the term "wobbly socket", gotta remember that one. I got a 3/8" drive x 10 and 13 mm one from Sears and find I use them quite frequently. Nice purchase. I saw mention that a 1/4" drive version was nice but didn't find I needed that myself.
great tools to have
i have found these socket adapters real handy and perfect for removing heat exchanger nuts just use an open end wrench and a short socket and better with a ratcheting wrench. is as handy as a regular socket wrench in tight spots harbor has them for about $10
http://forums.pelicanparts.com/uploa...1317306016.jpg |
I'm going to give my offset box wrench another try tonight.
I got them all off. The offset box wrench took off 2. And the dremel took off the last. So I have 1 broken one. I guess not bad out of 12. So do I need the $40 stud remover or are there.other ways.
Matt
Post a picture of the broken stud as well as what cylinder. Depending where it is you might need different approach. I had one on #6 outside that the stud puller could not be fitted. To my surprise ( was going to try anything at that point), got the sucker out with a bolt out. |
http://forums.pelicanparts.com/uploa...1317513441.jpg |
did you use heat, or just crank the nuts off? heat works on the nuts, but not so much on the studs. cut it flush, drill dead center with a pilot drill and finish with 17/64. if you were centered, there's just the threads remaining and they can be pulled out like a spring. that's the beauty of christian's tool. if you're off-center, finish the job with a timesert kit.
Good location, plenty of room to work with.
Start spraying PB Blaster but if the engine is still in it will not be going down the stud. You need a straight stud puller and an air gun. You start at 25 LB for about 20 seconds, and increase by 5 pound at the time. Mine got out at 50 Lbs. The straight stud puller Top Right on pics http://forums.pelicanparts.com/uploa...1298079901.jpg As soon as I can find the picks of the set up; Air gun/Puller/Stud I'll update. |
OK found the pics
This is a straight in line stud extractor. They seem hard to find, the place I got mine from does not carry them anymore and no result from Google!!! Found it... http://www.amazon.com/Titan-Stud-Puller-Drive-Model/dp/B00265M8N4/ref=sr_1_1?ie=UTF8&qid=1317529228&sr=8-1 (I pick up mine on sale at $10 at the Canadian version of HF Tool) http://forums.pelicanparts.com/uploa...1311697994.jpg http://forums.pelicanparts.com/uploa...1311698020.jpg http://forums.pelicanparts.com/uploa...1311698031.jpg |
[QUOTE=JJ 911SC;6286397]OK found the pics
This is a straight in line stud extractor. They seem hard to find, the place I got mine from does not carry them anymore and no result from Google!!! alright i'll bite, how well did it work? when i looked at the website it looks like a step drill..is it similar to a stud extractor, meaning it must be pre-drilled and centered to get it out..any chance of it snapping off? .thanks ,ben |
[QUOTE=56 nomad;6286627]
I have update to a different link. I got 7 of the 12 the studs using it. Amazon.com: Titan Stud Puller - 3/8in. Drive, Model# 16023: Home Improvement |
irrelevant on seized nuts but
I use Snap-On 1/4" 6 point wobble sockets. I can't confirm but I believe they're shorter than other brands. then nickle anti-seize on studs with new gaskets.. then recheck after a few run-cold cycles. Torque specs for the nuts are less than 20# |
I didn't have to use heat. They weren't much of a problem to come off. I had been PB Blasting them every day prior to removal. Then before I removed, I tightened the nuts first to break the rust. I forgot to do that on this one barrel nut and it broke the stud...so it was my fault. I probably could have done it with no broken studs if I hadn't done that.
I guess I'll try the stud puller first and if it breaks then I'll drill. |
Has anyone tried this stuff? Welcome to: Loctite® Freeze & Release
A mechanic on another site posted that he has great success with this stuff at times. |
My stud puller should be delivered today. Any tips for removal? I've been spraying PB Blaster on it. Should I use heat prior to removal?
Also, how do I clean up the other studs? Should I run the tap and die on them? |
Well snug on the stud (mid point, not flush with the head) and start at 20 Lb and increase in step of 5 Lb.
I did about 20 seconds at each steps. They came out at about 50. |
So the stud remover started to work, but then it ended up snapping the stud clean off. So now I have to drill (as JW said from the start). My question is, in order to avoid buying the drill jig, could I possibly cut off one of the flanges from my old HE,s and use that as a jig? I have an 83 which has the sleeves, so they would keep the "jig centered. What do you think?
just saw these, might be just the trick for the nut removal....
http://www.ultimategarage.com/Tools/j4757-lge.jpg |
That is too bad but at least, just like mine, its snap clean off. I would think that you would need a sleeve bushing as the hole for the stud is bigger then the drill size for drilling the stud. I did drill mind free hand but I end up having to put a Time-Cert in. While the jig is expensive, you can always sell it with little lost. |
