Hood fill gas cap/tank
Anyone know if someone makes these or do I have to hack my own tank? Or find an old factory race one?
I have seen the caps for sale but not the tanks.
Old 03-11-2005, 03:10 PM
Licensed User
Shuie's Avatar
I was able to modify a Blau cap and a readily available 3" cap & neck to work together
More than one way to skin a cat: Through the hood center gas filler project
The correct Blau filler necks are available outside of the states, details here.
http://www.early911sregistry.org/forum/showthread.php?t=5418
Heres a group buy that you missed out on. Get in tocuh with George and make sure you are on the list in case he does another group buy. It has been mentioned. that it may happen
http://www.early911sregistry.org/forum/showthread.php?t=5492
Old 03-11-2005, 03:14 PM
Any finish photos?
Old 03-11-2005, 03:27 PM
Licensed User
Shuie's Avatar
Of my car? No, its not done.
Im going to use the 3" neck in the first linked post and go straight up through the hood off of the passenger side of the tank like this car:
Old 03-11-2005, 03:40 PM
I would rather be driving
jpnovak's Avatar
Here is a link to mine.
ST Project: A hole in the hood part II!
Here is a pic of the finished product.
Old 03-11-2005, 04:12 PM
Send a message via AIM to Oldporsche
Cool
In looking at that filler neck, I think that one could be fabricated that bolted in place of the gas tank sender. This along with a fiberglass hood, and you would be very retro with little expense and effort.
David Duffield
Old 03-11-2005, 04:33 PM
ST Project: A hole in the hood part II! - Pelican Parts Technical BBS
I have been contemplating adding a center fill to my tank similar to the one above. While doing a search I came across this pic of what I believe is a 73 RSR. What is the second fill?
Old 11-06-2011, 02:48 PM
One is for fuel, the other is for a vent can so the fuel enters quicker.
1973 911S (since new) RS MFI specs
1991 C2 Turbo
Old 11-06-2011, 02:56 PM
Thanks RSTarga
Old 11-06-2011, 06:28 PM
