Drilling spot welds on hinge post, any tips.
I am trying to get the hinge post removed from a donor panel.... in the process of trying to drill out/ remove the millions of tiny spot welds on the panel I am pretty much destroying the donor panel .
is there any tricks to removing a hinge post? It also appears to be welded with lead at the top of the hinge post near the windshield corner.
Any tips appreciated.
Old 09-22-2011, 09:54 AM
So, there is no tricks or special tools for drilling spot welds?
Old 09-29-2011, 04:39 AM
na2ub's Avatar
I drilled a bunch using the appropriate diameter drill bit. As soon as it got dull, I sharpend the tip with my dremel. Once you drill through, you can separate any remaing metal with a chisel. Air chisels help.
Better yet, there is a spot weld drill bit, that has a centering drill and a round cutting blade. I have not used one, but I hear its the way to go.
Doug
79 SC Targa w/ ITBs, 2004 Cayenne Turbo
Old 09-29-2011, 05:03 AM
Thanks for that,
I will look into that today.
Old 09-29-2011, 05:35 AM
gwmac's Avatar
I had the same problem with my suspension pan replacement, ended up using an angle grinder with a very thin blade and grinding the welds sacrificing one side. as you grind the weld you can tell when you get through, the metal will turn blue as it gets very thin.
worked much better than the spot weld cutter i was using and no holes to fill in.
Old 09-29-2011, 05:59 AM
Insert Tag Line HERE.....
rattlsnak's Avatar
yes, there are special tools and it makes the job MUCH easier.
see this: SG Tool Aid 18000 3/8 Rotary Spot Weld Cutter
I have never used that one, but I have a set from Snap-on. The center pin is spring loaded..
Old 09-29-2011, 06:25 PM
Harbour freight also has the spot weld drill bit for $4. i was surprised at how well it worked on my suspension pan removal and i didnt even have to flip it over to a new sharp edge once! Does drill the holes a little bigger than i would have like though.
1975 911 race car build in progress
Old 09-29-2011, 09:43 PM
