-   -   Is this clutch release fork re-useable? (http://forums.pelicanparts.com/porsche-911-technical-forum/632302-clutch-release-fork-re-useable.html)
Hotwatermusic 09-29-2011 08:09 PM
I am trying to assess what needs replacing in my clutch. I've been told my clutch plate has a lot of miles left on it, and my flywheel looks good. What about this clutch release fork though? There are no cracks at the normal places, but there are light scratches and minor scuffs on one arm.
http://forums.pelicanparts.com/uploa...1317351882.jpg
http://forums.pelicanparts.com/uploa...1317351957.jpg
http://forums.pelicanparts.com/uploa...1317352075.jpg
Oh Haha 09-30-2011 04:11 AM
It appears fine to me.
KTL 09-30-2011 07:13 AM
Put a slight amount of extreme pressure grease on those contact points when you reinstall the fork.
HawgRyder 09-30-2011 10:11 AM
I had a fork that looked similar...but worn a little more.
I welded on some hard coat and ground it down smooth afterwards, polished, and lubed before re-install.
Worked for me...but with yours...it depends on the amount of wear.
Bob
j911brick 09-30-2011 12:13 PM
I'd replace it. The clutch will operate allot smoother.
RWebb 09-30-2011 12:56 PM
just toss it - they often crack near the base of the horseshoe
new one is cheaper than testing it and then there's the wear...
