-   -   ITG Air Filters- Water a Problem? (http://forums.pelicanparts.com/porsche-911-technical-forum/632430-itg-air-filters-water-problem.html)
KTL 09-30-2011 02:32 PM
I see these filters on a number of racy engines. Can these be used in a wet environment? I assume no....
I have K&N filters and watershield covers on my 3.0 and i'm not a big fan of the K&N filters. I wouldn't mind using a factory air cleaner housing with paper filters, but I need the middle clear to access/clear my ignition board and wires (Electromotive HPV-1)
Thanks,
Kevin
Steve@Rennsport 09-30-2011 04:45 PM
Nossir, not without covers.
Thanks,
Kevin
Options are limited, as you know for air cleaners on carbs & ITB's. Both Jenvey & ITG make foam aircleaners of different types as well as K&N's oiled-gauze ones comprise all the choices for these applications.
In the context of race cars, these are all OK, but maximum potential engine life might be shorter when using such things. There are steps we take to help ensure these work to their best ability such as applying grease to all the edges for improved sealing.
KTL 10-02-2011 06:26 AM
Thanks for the reply Steve. Are covers available for the ITG filters, or is it a custom fabricated solution?
Steve@Rennsport 10-02-2011 08:22 AM
AFAIK, there are no ready-made solutions; you will need to be creative.
lupin..the..3rd 10-02-2011 08:30 AM
It would be nice if someone could develop a filter housing for carbs / itbs that uses a readily available paper panel filter. there are several small cars that take a long narrow panel filter that's about the right size. peugeot 207/307 comes to mind, that filter is around 10 cm x 30 cm.
KTL 10-10-2011 11:58 AM
Agreed that somebody ought to have made a paper element for these carbs. Seems like there'd be a somewhat reasonable demand to justify the creation of one. I assume Weber, Zenith, Solex simply relied on use of the factory filter housing snorkel plenum?
Looks like i'll have to cook up some shielding of my own in the engine bay. Not a big fan of the K&N filters.
911pcars 10-10-2011 05:14 PM
I have them too. Have you tried a test with some water sprinkled over the filter (uninstalled that is)? I'm thinking the oil-impregnated foam provides some measure of rain filtering. If it leaks a little water, I think this would be more of an issue at rest rather than running. After all, you do drive in the rain, yes?
For a K&N-type housing, you'll want a 12" OD round filter. I found a source while roaming through Google, but they're only 2" tall. Try this:
Spectre/12 in. o.d. x 2 in. oval air cleaner filter element (4808) | | AutoZone.com
MotorMeister used to sell Tru-Flow foam filters to fit K&N housings, but if you keep your engine out of the equation, they might be okay to deal with.
Sherwood
(no affiliation)
http://forums.pelicanparts.com/uploa...1318295632.jpg
KTL 10-11-2011 02:01 PM
Thanks for the reminder about the True Flow filters. I had forgotten about those. Did some searching and they're near impossible to find. May have to do some direct contacting to see where I might get some. Hard to patronize MM even if they don't have my engine, given the number of people skunked by their routine.
Appreciate the feedback as always.
Kevin
