-   -   Help needed - Clutch helper spring (http://forums.pelicanparts.com/porsche-911-technical-forum/632516-help-needed-clutch-helper-spring.html)
Va_Powerman 10-01-2011 11:14 AM
In trying to replace my clutch helper spring so that my wife can drive the car while I'm gone (deploying to Kandahar in two weeks), I'm a bit stuck.
Pulled the old broken spring off, reassembled the arm, and everything appears ok . But, in the process of reassembly I've got a few problems:
- the clutch pedal was depressed, and now is flat on the floor;
- the new spring is physically larger than the older, and I cannot get it to seat, so cannot get the arm back into its seemingly correct position;
- I'm not sure if, once the arm is seated, if the clutch itself will function....
Basically, I'm stumped, and could used some "real time" help!
Va_Powerman 10-01-2011 11:16 AM
Here's a pic of where I am - Thanks!
http://forums.pelicanparts.com/uploa...1317492958.jpg
E Sully 10-01-2011 12:44 PM
You seem to have the spring on wrong, flip it over. Here is a pic of the correct setup.
http://forums.pelicanparts.com/uploa...1317498189.jpg
E Sully 10-01-2011 01:13 PM
A few extra details for adjusting.
http://forums.pelicanparts.com/uploa...1317499975.jpg
Va_Powerman 10-01-2011 05:34 PM
Ahhhh, thank you. I'll flip it tomorrow morning - much appreciated!
Hugh R 10-01-2011 07:23 PM
Make sure the spring is against the heat exchanger, when flipped, it will also go in another position which you can rectify with a large screwdriver.
Va_Powerman 10-02-2011 08:14 AM
Magic. Thank you gentlemen.http://forums.pelicanparts.com/uploa...1317568449.jpg
