-   -   Lots of fan/alternator questions (http://forums.pelicanparts.com/porsche-911-technical-forum/632666-lots-fan-alternator-questions.html)
masterdave 10-02-2011 10:41 AM
So about 2 moths ago i started to hear a rattle from my engine. I was able to trace it to the fan rubbing against the fan housing. I also noticed a few days latter that 2 of the blades had small chips on the edges. This was right before the car went in to storage. I will be heading back to it next weekend and can final get some work done on it. These are the things I am trying to figure out.
I think it is the alternator bushings, thats what many have told me the issue may be so im going to replace them. Does any one have a part number on these things. The car is a 78 911sc, i cant get the alternator part number until I get home next weekend?
What is the best way to adjust the fan belt/are there any special tools I will need? The belt may just be lose?
I am going to remove the fan and housing, most likely replace the fan because of the chips, but i am going to paint them both, what is the best type of paint/ do i need to sand blast them first?
The most important questions is, should i drop the engine to do all this. Will it make it that much easier that its worth doing. If i need to do it, can i drop it with nothing but jack stands?
Does any one have an 11 blade fan for sale??? I would be very interested.
Dave
CorsePerVita 10-02-2011 10:47 AM
I powdercoated my fan. In my experience on moving parts, unless you have done really fantastic prep work, it has a tendency to flake off. Although if you are sandblasting it or using a wire wheel then it'll have a much better chance making it stick. But a good powdercoat and the paint isn't going anywhere :)
Before
http://i225.photobucket.com/albums/d...1/DSC_0055.jpg
After
http://i225.photobucket.com/albums/d...1/DSC_0290.jpg
masterdave 10-02-2011 01:09 PM
That fan looks great, did you powder coat it your self, or have it done?
