-   -   Boge or Bilstein (http://forums.pelicanparts.com/porsche-911-technical-forum/632780-boge-bilstein.html)
rgshukri 10-03-2011 12:29 AM
Boge or Bilstein
Hello All:confused:
i hope anyone can help me out here
I was installing the from strut mount (weather sealed monoballs) when i discovered that the right hand side shock strut is green and the left hand side is black.
based on Pelican parts, green is bilstein and black is Boge
How can i be sure which is the correct one for my car?:confused:
thanks in advance
regards
Rudy
Christien 10-03-2011 06:51 AM
Make sure it's truly black and not road grime. I thought mine were boges until I found the roll pin at the bottom. The grime was ridiculously thick, and they were completely black. Hit one with some brake cleaner and steel wool to be sure.
rgshukri 10-03-2011 05:51 PM
yes I am sure
the BOGE word is stamped on it
thanks
Christien 10-04-2011 02:21 PM
Well, that IS sure! :) Both work, if the right shock insert is purchased. I'm guessing you probably have Boge strut assemblies - there are Bilstein shocks that fit the Boge assembly, so someone probably just replaced one shock somewhere along the way at some point. You should be able to replace with either, though Bilstein is the preferred choice. If you really want to be sure, find a part # on each one and compare to the Pelican catalogue:
Porsche 911 & Carrera Suspension - Page 1
Judging by your facebook pics, I'm assuming you're driving a 3.2 Carrera. Might be a good idea to list your car in your sig, to avoid confusion .
dshepp806 10-04-2011 05:06 PM
I've remained the bastard child,..as I just installed Boges on the rear (factory) and will soon load Boges on the front, as well.......want to keep her this way.....all will be fine.
BEST!
Doyle
