-   -   Help with my power windows (http://forums.pelicanparts.com/porsche-911-technical-forum/632904-help-my-power-windows.html)
Barenecessity 10-03-2011 04:24 PM
A couple of days ago the driver's side window came off its track (thunk). Today I took the door apart (see photos below) which included unplugging the two toggle window switches. After jiggling the window for a while I realized that I had to lower it all the way down to give me the necessary access and space. I re-attached the window switches and . . . nothing. Nothing worked. Not driver's side, not passenger side. Fuse is good.
Am I missing something? Do the switches work independently - can one work without the other being functional?
Any help would be greatly appreciated
BN http://forums.pelicanparts.com/uploa...1317684191.jpg
zippy_gg 10-03-2011 05:04 PM
I suspect you crossed some wires when you reconnected the switches.
Do you have a wiring diagram for your year model?
fbeatty 10-03-2011 05:24 PM
Try jiggling or disconnecting/cleaning/reconnecting the wires on the motor (in the door) itself. Mine gives me a problem every now and then and it won't work. This usually gets it working again.
86 911 Targa 10-03-2011 05:45 PM
Hope this helps.
Good luck,
Gerry
http://forums.pelicanparts.com/uploa...1317688976.jpg
http://forums.pelicanparts.com/uploa...1317688998.jpg
http://forums.pelicanparts.com/uploa...1317689026.jpg
Barenecessity 10-03-2011 07:25 PM
Thank you. Tomorrow morning I'm going to re-check the wire connections on the toggle switches based on Gerry's diagrams. I will also work on the wire connections to the motor. I will keep you posted on success/progress.
Thanks again
BN
Barenecessity 10-04-2011 07:53 AM
stumped
I checked and re-checked the wire connections. Window motors still don't respond. Question: if one switch is improperly wired will that cause both switches to stop working - are they linked? If they are not linked, then the fact they are both malfunctioning might indicate something wrong further up the line. I keep going back to the fuse but it is still ok.
ipacketeer 10-04-2011 08:08 AM
Hi, i would make sure that the Relay controlling the power Windows is working. I usually replace it with a known working one, to test that the Relay is not the culprit. Good luck.
86 911 Targa 10-04-2011 08:46 AM
Fuse?
gamin 10-04-2011 08:56 AM
Had same prob on my 88. Big pita. Bentley man has good diag for win switches. What color wire to which numbered blade on back of switch. Be sure to use diag for your year. Check relay. Don't know what year you have. Earlier have round relay in trunk. Later have square relay behind drivers side dash. Easy access for both. You can run the window motor up or down using battery charger on 2 amp and wires with alligator clips attached to motor blades. Reverse to change direction.
Barenecessity 10-04-2011 09:35 AM
Relay?
Ok, I was not aware of a relay for the windows. I must admit that I am not impressed with the URO relays. I replaced all my relays (the black round ones) and my red fuel pump relay a week ago. Pulled the old ones off and put new ones on. The new red one did not work well so I went back to the old one. One of the black ones, the one in the engine compartment, the top came off like a bottle cap without hardly any pressure - just downward pressure to plug it in.
I guess I have to look at the manual to identify the relay for my windows.
Will let you know the outcome . . .
BN
Barenecessity 10-04-2011 11:08 AM
BAM! it was the relay
It was the brand new URO relay I installed several days ago. That's three brand new bad relays in a row . . .
86 911 Targa 10-04-2011 11:50 AM
URO Relay
Many P-Owners have incurred out-of-the-box failures on many URO products.
To call URO products garbage, would be a compliment!!!!!!!!!!!!!!!!!
Joe Bob 10-04-2011 11:59 AM
Gotta love this crap...
Quality Assurance
A.P.A. Industries, Inc. is proud of the exemplary reputation of our ÜRO Parts product line. In order to uphold this reputation, significant measures are taken to prevent premature failures and/or defective parts.
All of ÜRO Parts manufacturing facilities are ISO 9000 certified to ensure manufacturing standards consistent with the highest levels of quality.
Every ÜRO part also undergoes one or more of the following measures in order to make certain that each part meets or exceeds OE standards for fitment, function, durability, and design:
Installation and use of the part in real world conditions for a specified duration of time
Laboratory testing of rubber and metal compounds for tensile strength, shear strength, compression strength, elasticity, stiffness, etc. under extreme conditions
Intensive factory and local inspection of each part against genuine samples and engineering drawings to ensure consistent quality every time
In the unlikely event one of our products fails, the distributor can contact us for a fast and no hassle return.
All ÜRO Parts come with an industry leading 24 month unlimited mileage warranty against defects in materials and workmanship. All warranty returns are carefully scrutinized to determine the cause of failure so corrections and improvements can be made. At ÜRO Parts, quality is an ongoing pursuit that never ends.
The ÜRO Parts product line offers you the peace of mind that your company is both offering the best parts to its customers and getting the best value. Gain an advantage over your competitors with ÜRO Parts.
This warranty is valid only on parts installed by qualified personnel and in the application for which they are intended. Parts that are altered, abused, or subjected to arduous use may be excluded from warranty coverage.
86 911 Targa 10-04-2011 01:14 PM
Quality Assurance
All of the above sounds soooooooo convincing, until one is stranded on the freeway, or on some back road
with a newly installed uro relay.............
redridge 10-04-2011 01:32 PM
Sorry, but everyone in the industry know that ISO certification is all marketing mumbo jumbo crap....
nineball 10-04-2011 02:42 PM
not sure if they are all connected but i know on my SC if all of the wires are not connected on the driver side (both switches) the passenger window will not work. chances are good that they are like the old christmas lights - remove one wire and they all stop working.
86 911 Targa 10-04-2011 05:37 PM
Correct:
Here's the 84-86 CKT which, with the exception of wire color, is identical to the SC's.
http://forums.pelicanparts.com/uploa...1317775036.jpg
