Helios59's Avatar
New H4 Headlight Bulbs
Hi All,
I think it's time to pop some new bulbs into my Bosch H4s. I dipped into our sponsor's parts bin and found Hellas are 6 bucks apiece while Genuine Porsche is 17 apiece.
I want bright headlights...should I spring for the Porsche bulbs?
Thanks!
Ray
1986 Turbo-Look Cab
White Gold/Burgundy
Old 10-03-2011, 05:35 AM
ivangene's Avatar
you have relays I hope....
bright bulbs might stress those old wires more than you are really wanting....
Ed M
86' Coupe
Old 10-03-2011, 05:39 AM
Formerly known as Syzygy
Canada Kev's Avatar
Those Porsche bulbs arfe probably Osram or Phillips. Or maybe even Hella. Just pick up some from one of the major players and you'll be fine.
And a big +1 for Ed's comment.
Kevin
Old 10-03-2011, 05:58 AM
porwolf's Avatar
I am in the process of changing sugar scoops to Euro H4's. For those I got the OSRAM BILUX 64193 NPB 12V60/55W H4U37R lamps which were highly rated in a German comparison test. I wanted the asymmetric low beam pattern which only comes for the 60/55W lamps.
This, of course, is the asymmetric low beam pattern:
For asymmetric adjustments I found a good instruction:
Daniel Stern Lighting Consultancy and Supply
79 SC Targa
72 T Targa Sold
68 T Coupe Sold
65 912 Coupe Sold
62 356B Coupe Sold
Old 10-03-2011, 02:19 PM
gtc gtc is offline
abides.
gtc's Avatar
80/100W H4 bulbs are a nice improvement over the typical 60/55W bulbs.
Graham
1984 Carrera Targa
Old 10-03-2011, 03:49 PM
Canada Kev's Avatar
What you indicate for your lamps are just the bulbs that go into the H4 headlight reflector and lens assembly. The "asymmetric low beam pattern" to which you refer is created by that reflector/lens assy (Euro H4 lights) and not the bulb. Regardless which bulb you install you will get that beam pattern.
BTW, you will love the light output of the Euro H4s. They are a huge improvement over sealed beams.
Kevin
Old 10-03-2011, 05:06 PM
Canada Kev's Avatar
Ain't that the truth, Graham. That's what I did, though I am a bit concerned that I may be taxing the factory wiring. I have relays but haven't yet got around to installing upgraded newer wiring to the lights from the relays. It makes me nervous having all that juice running through quarter century old (and more than likely undersized) wire.
Sure is bright, though...
Kevin
Old 10-03-2011, 05:10 PM
porwolf's Avatar
Hi Kevin,
when I bought my Osram H4 bulbs (Identical to German bulbs) I researched whether the bulb itself is designed for the asymmetrical low beam geometry. I came to the conclusion that the German bulbs are, because it is standard there. Also, there seems to be a difference in the shape of the internal metal blades. In addition my new Bosch Euro H4 housings seem to have sockets where only asymmetric bulbs fit in. It has to do with the tabs on base of the bulbs. At least that is what I remember.
Wolfgang.
79 SC Targa
72 T Targa Sold
68 T Coupe Sold
65 912 Coupe Sold
62 356B Coupe Sold
Old 10-04-2011, 12:00 AM
Helios59's Avatar
I should mention that I have a German-market car that was Federalized in 1986 when it was imported.
Does that make a difference in the type of bulbs I need?
Ray
1986 Turbo-Look Cab
White Gold/Burgundy
Old 10-04-2011, 03:48 AM
porwolf's Avatar
Hi Ray,
If you still have the German H4 head lights probably all 60/55 H4 bulbs will fit. I still think for the best asymmetric light pattern you should get the same H4 light bulbs that are also used in Germany.
79 SC Targa
72 T Targa Sold
68 T Coupe Sold
65 912 Coupe Sold
62 356B Coupe Sold
Old 10-04-2011, 11:02 AM
lupin..the..3rd's Avatar
Send a message via AIM to lupin..the..3rd
I had H1's on my old car, and had it wired so that when the high beams were on, all four bulbs illuminated. Oh, and I had four 40A relays, and four 80/100w bulbs, and all 12 gauge wiring. Switching the high beams on at night gave 400w of illumination; it literally turned night into day. A quick flash of them was more than enough to wake even the sleepiest nighttime motorist.
SOLD: '87 Carrera
Old 10-04-2011, 01:08 PM
