-   -   Replacement oil hard lines - this machine would help (http://forums.pelicanparts.com/porsche-911-technical-forum/633323-replacement-oil-hard-lines-machine-would-help.html)
Grady Clay 10-06-2011 06:36 AM
Very cool:
EarlyS member advtracing from Auckland, NZ
on EarlyS Registry Forum Replacement oil hard lines - this machine would help
posted this remarkable video:
[video=youtube;ot0Cxmk2aa4]http://www.youtube.com/watch?v=ot0Cxmk2aa4&feature=player_embedded[/video]
<object width="640" height="360"><param name="movie" value="http://www.youtube.com/v/ot0Cxmk2aa4&hl=en_US&feature=player_embedded&versi on=3"></param><param name="allowFullScreen" value="true"></param><param name="allowScriptAccess" value="always"></param><embed src="http://www.youtube.com/v/ot0Cxmk2aa4&hl=en_US&feature=player_embedded&versi on=3" type="application/x-shockwave-flash" allowfullscreen="true" allowScriptAccess="always" width="640" height="360"></embed></object>
from
Pipe Bending | Tube Bending | Handrail Fittings | Sharpe Products, WI - Home
Surely there is one of these that can copy an existing oil pipe and produce instant copies.
Sorta ‘photocopier’ of the pipe industry.
Just feed it seamless brass tubing and silver-solder on fittings.
Just think, you could take a tubing bender ‘hicky’ and some EMT, bend it to fit your application and (after some trial-&-error) have it replicated in brass.
You could even replicate the '69-'71 911S in-the-chassis pipes, the 914-6GT pipes, the 356 Carrera front cooler pipes or (if you want larger that the 25 mm pipe) use any size.
Another ER ‘service’. Chuck, take note. :cool:
Best,
Grady
