83 911 Production Cab #10
Who Will Live... Will See ![]() ![]() ![]() 83 911 Production Cab #10, Slightly Modified: Unslanted, 3.2, PMO EFI, TECgt, CE 911 CAM Sync / Pulley / Wires, SSI, Dansk Sport 2/2, 17" Euromeister, CKO GT3 Seats, Going SOK Super Charger |
Northern Motorhead
Still need to know what size triple square bit i need ... I measured the 55 Torx bit and it's 11mm,just need to confirm the triple square size ...
Cheers ! Phil
Cheers Phil 89 Coupe,Black,95 3.6 engine and the list goes on ... 1983 944 SP2 race car PCA #96 |
Phil
Its a 12 mm. I did not have to use air gum to removed them. The trick is to be totally square off as the bite is very shallow. I could ship you mine but thanks to Post Canada it would be cheaper to buy one.
Northern Motorhead
Hi JJ,
I ordered a 10 and a 12 from my local auto parts store,they're only $4.00 each so i'll be good to go. Thank you for your consideration and the info! I know you did an engine drop recently,any tips while i'm there ! Did you ever get your car back on the road this Summer ? I have a crankcase gasket kit on the way so i'll be replacing whatever seals and "O" rings that come with the kit ... Cheers ! Phil
Hey Phil
Yeah, finally got her on the road late August. Start on the second try, what a relief. The sound of the SSis mated to a 2In/2Out was worth the wait according to the guys behind me ![]() Well might biggest tips is, resist the "while you are in there impulse" it could be expensive...If you leak from anywhere, its a good time to fix them, especially the Oil Triangle of Death (crankcase breather, thermostat & the idiot light. Good time to change the Oil Idiot light, under $5. Since you got a G50 transmission, the drop is straight down unlike with the 915. Take a lots of pics and notes as you might not remember everything when the engine go back in. Have fun JJ
Puny Bird
Sorry to dig up an old thread, but if any Canadian peeps are looking for the tri-square bit/socket Princessauto (Canadian version of Harbour Freight) carries 4 different sets from $17. to $30.
'74 Porsche 914, 3.0/6 '72 Porsche 914, 1.7, wife's summer DD '67 Bug, 2600cc T4,'67 Bus, 2.0 T1 Not putting miles on your car is like not having sex with your girlfriend, so she'll be more desirable to her next boyfriend. |
Irrationally exuberant
I have nice German ones (Stahlwille) but I was in a pinch
once and got some from my local parts place. They don't have a socket that you could use a ratchet on. Instead they have just a straight shaft; think of an Allen key without the bend. You hold the non-triple square shaft end with a socket. They are apparently made of a structural cheese (soft). They rounded over after a couple uses. Not recommended.
'80 911 Nogaro blue Phoenix! '07 BMW 328i 245K miles! http://members.rennlist.org/messinwith911s/ |
I used this, <$7 at Amazon shipped. Don't know how I used to get by before internet shopping.
https://www.amazon.com/gp/product/B00ESN0032/
Matt - 84 Carrera |
Puny Bird
If you do a lot of VW and Porsche work you need:
8mm, VW and 914 CV's 10mm, 996, flywheel and trans (I believe fly might be 12mm) 14mm, 911, flywheel, VW T4 auto trans flywheel (TC mount plate)
'74 Porsche 914, 3.0/6 '72 Porsche 914, 1.7, wife's summer DD '67 Bug, 2600cc T4,'67 Bus, 2.0 T1 Not putting miles on your car is like not having sex with your girlfriend, so she'll be more desirable to her next boyfriend. Last edited by Mark Henry; 02-02-2017 at 07:56 AM.. |
