Odd part found in fuel dist. 2.7 CIS
'75 911 2.7 cis fuel plunger part? I have been researching the web and my Bentley Bosch manual to try and locate a small 'cup' I found in my fuel inlet on the top of the fuel distributor. I thought it was a piece from thetop or tip of the plunger but now am not sure because no where can I find it in any other diagram or disassembly picture.
it's supposed to be above the plunger, and not supposed to be loose. when it gets damaged, the plunger and sensor plate can oscillate rapidly. there's a tiny hole in the top.
Thanks for the reply! Is there any chance I can remove the plunger and reinstall it or is there no choice but to have it rebuilt? The process of removing the plunger does not scare me but I don't know if there is any advantage if it will remain loose and possibly pop out again or run poorly. How was it originally attached?
it was pressed in. if you look with a flashlight through the upper port, you can barely see the top of it when it's in position. be sure the tiny pin hole isn't distorted. you will have to figure out how to slightly expand it so it stays put, as well as what kind of installation tool it needs. then hope it stays put. you probably will need to find another unit.
https://www.instagram.com/johnwalker8704 8009 103rd pl ne Marysville Wa 98270 206 637 4071 Last edited by john walker's workshop; 09-26-2011 at 05:13 AM.. |
Thanks again. I will give it a go tomorrow and post the results.
Cheers! |
be super careful removing and installing the plunger. don't drop it or scratch it. the tolerance is so exact that fuel does not pass between the plunger and bore, and there are no seals. likewise, do not touch the bore with whatever tool you use to try and press that piece back in.
http:// ![]() Also, it may help to know that this car sat 7 years with no fuel in it. After repairing the fuel tank, clearing the lines and pump and a new filter this is the next step in revival. I expected to find varnish in there but not this. Last edited by buffarea; 09-26-2011 at 06:47 PM.. |
Odd part-I'll call it a 'cup' for now.
Today I was able to remove the fuel distributor and plunger to try to figure out what this little loose cup thingy is. First off there is no hole what-so-ever in this cup. It is knacker a bit and I was unable to gently insert it from the inside, and although maybe it belongs there, I'm thinking if it does it is inteneded to 'float' and not be pressed into the hole.
it does not free float and there is a hole in the center. a very small hole. how do to think control pressure gets in on top of the plunger?
It is all back together now, freed up including smooth operation of the throttle plate. I just ran out of time but tomorrow will reinstall the plugs and see if it will start. |
Quick update. Replaced plugs, still no start. Out of time again but frustrated and losing interest.
