-   -   Caliper Rebuild, why 20°? (http://forums.pelicanparts.com/porsche-911-technical-forum/6343-caliper-rebuild-why-20-a.html)
emcon5 07-22-2001 10:17 AM
I rebuilt the calipers on my 82 SC yesterday.
I set the pistons at the required 20° angle, as specified in the instructions, as pictured below:
http://www.pelicanparts.com/techarti...uild/rotor.GIF
What I don't understand is why. What is the purpose of the relief on the pistons, and what is the significance of 20°?
No other car I ever owned had anything like this.
Thanks,
Tom
82 911SC Coupe
Don in Redondo 07-22-2001 10:31 AM
To aid in the release and retraction of the piston without vibration. Many other auto designers use heavy return springs and beefier piston caliper setups, that are cumbersome and require more parts to effect the same outcome.
Downside is that P. brakes are more prone to pad drag and pedal slop when things go wrong.
movin 07-22-2001 02:02 PM
I recall the same thing being accomplished by other manufactures by placing a Squeal Shim configured in similar fashion between the piston and the pad. Looks like Porsche wanted to do it the hard way again.
orbmedia 07-22-2001 03:34 PM
I thought the angle was for uniform pressure application across the pad surface and even wear.
Roland Kunz 07-22-2001 08:59 PM
Hello
The reason is that the disc has different speeds from the inner to the outher circle so this will generate a spin impulse to the pistons on the long run.
Grüsse
