-   -   Camber plate replacment/alignment (http://forums.pelicanparts.com/porsche-911-technical-forum/634584-camber-plate-replacment-alignment.html)
kent olsen 10-13-2011 07:48 PM
Question is whether or not to realign the front.
1972 911T. I had to replace the Weltmeister camber plates, that's another story. I put the new one's in, replaced the strut bar between the tower's, ( one at a time leaving one side always attacted). Should I have it realigned or is it possible that I might end up with the same front camber?
DRACO A5OG 10-13-2011 08:32 PM
If you are lucky and did not disturb the alignment, sure but most likely it is off now after your install.
Both Camber and Caster. Sorry to be the bringer of bad news :(
