Pierre911SC's Avatar
Question Window seals on doors
Hello Gents,
I am in the process of getting my car, ready for painting this winter.
The whole job will requirer removal of all windows with seals replacement.
So far, looks like I got most of them, except for the one shown
with the yellow arrow.
Is that seal available ? And how to replace it ?
Also, is all the work on the upper door (red arrow)can be removed ?
Can it be "reanodize" or painted ?
Thank you all.
Regards
Pierre
stsrobotic@yahoo.ca
82 911SC wide body, 3.6L
Old 10-14-2011, 10:51 AM
E Sully's Avatar
Part 81 Window outer seals. Trim can be reanodized or painted.
Porsche 911 & Carrera Front End Seals - Page 4
Ed
1973.5 T
Old 10-14-2011, 11:12 AM
Thank you ED, I found it.
Is the seal just clip in ? How to removed ?
Pierre
stsrobotic@yahoo.ca
Old 10-14-2011, 09:50 PM
Weekend Mechanic
vulcan300's Avatar
That seal slides onto the metal strip beneath it. The metal strip is attached to the door by a number of metal clips that snap into holes in the top of the door. To remove the metal strip gently pry from underneath starting at one end. Once the metal strip and seal are removed from the door you can slide off the seal.
86 911 Carrera Targa
Old 10-14-2011, 11:20 PM
Any pictures of the assembly would be much appreciated.
Thank you.
Regards
Pierre
stsrobotic@yahoo.ca
Old 10-15-2011, 11:55 AM
