cmcfaul's Avatar
Send a message via AIM to cmcfaul Send a message via Yahoo to cmcfaul Send a message via Skype™ to cmcfaul
cold start valve on 73 911 E
My cold start stopped working so I now run it right off the starter (engaging the starter sends 12 volts to the enrichment solenoid that sends gas directly down the stacks). Works great but can flood the engine when started hot. What is supposed to tell the cold start circuit not to work when the car is hot?
Thanks,
Chris,
73 911 E - MFI
Old 10-06-2011, 01:37 PM
In maintenance phase
daniel911T's Avatar
You could always install an on/off switch in the cab...
Kind of a smart ass answer, but I've flown several airplanes that had electric primers. Sort of the same thing.
-Dan
1969 911T (Getting a 72E heart transplant)
2004 Volvo XC70
Gone, but not forgotten:1971 Bug, 1978 Bus, 1982 Westy, 1996 GTi, 2000 Audi A4 2.8, 2001 Jetta Wolfsburg 1.8T, 2002 Audi allroad 2.7T, 2010 Jetta SportWagen TDi, and a couple of short lived 914s.
Old 10-06-2011, 01:42 PM
cmcfaul's Avatar
I have contemplated the same thing (the switch) but would like to see if I can fix it right before I make my jerry rig more perminant.
Chris
Old 10-06-2011, 01:44 PM
daniel911T's Avatar
Chris
Install a really nice switch?
2004 Volvo XC70
Old 10-06-2011, 01:48 PM
daniel911T's Avatar
How about this:
and this:
It's red. It will certianly make your car go faster, kinda like red brakes.
2004 Volvo XC70
Old 10-06-2011, 01:55 PM
Bandwidth AbUser
Jim Richards's Avatar
From a thread that's a few years old.
Originally Posted by Peterfrans View Post
there is a coil in the thermo time switch which warms the switch (does this make sense?). Above a certain temp the switch opens and the circuit to the solenoid is broken. The temp of the switch is dependend on
- ambiant temp
- engine temp
- coil in the switch
After a few starting attempts the switch will be so warm that is does not close anymore, hence no extra fuel through the cold start injectors
Jim R.
Old 10-06-2011, 02:06 PM
cmcfaul's Avatar
A pic would be great as I know what it's called but not what it looks like.
Many Thanks,
Chris
Old 10-06-2011, 02:15 PM
Bandwidth AbUser
Hi Chris,
It looks like this
and on my old 73E, it was on top of the engine just to the right of the MFI injection pump.
Jim R.
Old 10-06-2011, 02:24 PM
I installed a push-button type switch in my 73 T, there's a perfect spot on the dash, just to the right of the steering column, kinda opposite the ignition switch. If you reach up behind the dash, you find the factory hole, no drilling.
73 911 T MFI Coupe, Aubergine
Old 10-06-2011, 02:45 PM
cmcfaul's Avatar
I think I see the thermo switch. Kind of hard to see without taking the air cleaner housing off but it looks like it sticks out of the oil...cover to the right of the MFI pump.
Does it complete the circuit when cold and break it when hot? (hopefully) In other words, if I install the wire from the starter to the Thermo switch and the other side of the thermo switch to the cold start solenoid. This should stop the cold start from working when the engine is hot. yes? If no my solution gets more complicated.
I am hesitant to install a switch or anything that is not stock. The value of these cars is largely in originallity. It is easy to slowly but shorly get further and further away from the way it is supposed to be.
Chris
Old 10-06-2011, 03:21 PM
Plays with cars's Avatar
Yep, it's called a thermotime switch and is installed in the crankcase breather cover on the rear center of the engine. Our host sells replacements: Porsche 911 Mechanical Fuel Injection - Page 1
The switch is closed when cold, open when hot.
Mark B
'73 911S (long term ownership) '70 914-6 (long term project) '74 914-2.0 (sold)
Old 10-06-2011, 10:31 PM
cmcfaul's Avatar
perfect and thanks,
Last question, does the Thermo time switch do anything other than the cold start circuit? Will I freak somthing out by sending 12 volts from the starter through the switch?
Chris
73 911 E MFI
Old 10-07-2011, 06:20 AM
Nope. That's all its for.
Mark B
Old 10-07-2011, 08:13 PM
thor's Avatar
Button wiring
Hello
I' m really interested to Know how you wired your manual switch for the cold start valve you have mounted on your dash
CAN you help me ?
Old 10-16-2011, 09:42 AM
cmcfaul's Avatar
Sorry, no switch here. If I was to do one, would prob just mount it to the rear tunnel cover. Only need to use the switch when starting a hot engine (to turn off the cold start).
Chris
Old 10-16-2011, 01:33 PM
thor's Avatar
I think steve (regency)did it
I Would like to Know more
Old 10-16-2011, 02:12 PM
Hi Thor, in my case, last Summer i got stranded three times. All three times it was hot out and I couldn't get re-started. Finally figured out that the solenoid that sits above the fuel filter and feeds those small cold start lines in the stacks, wasn't working or wasn't getting the signal from the CS switch. I found a cool push button switch that surprisingly looks stock. I wired the switch directly to my new push button switch now installed in the dash, almost opposite the ignition.
Now, when I push the switch, I can here a click as the squirt of fuel is released.
I've only had to use it a few times since I installed it but I'm glad I have it.
Hope that helps you.
Old 10-16-2011, 02:44 PM
thor's Avatar
You Didn t use relay ?
I restore all but i Also realize this timeswitch wasn t working properly and you do not need some much fuel to start engine ....
Old 10-16-2011, 10:43 PM
