-   -   Need Zenith rebuild help (http://forums.pelicanparts.com/porsche-911-technical-forum/634973-need-zenith-rebuild-help.html)
vwbobd 10-16-2011 02:01 PM
i have taken these things apart as far as they will go and I still cannot find where all these little o rings and a few of the big red seal go. are there useless parts in the kits? I'm afraid I have over looked something. I have 3 each of 2 different size very small black orings left and six large red washers almost big enough to put on my pinky finger. Everything big enough for these has a new seal installed from the kit already. The expoded view is useless that came with the kit. I installed the only o rings that would fit in the groove of the idle adjustment screws but there are two grooves on the screw and I dont have any other ones small enough to fit that eill fit in the hole when installing screws back in body. I'm at a loss.??? I have built many carbs before but this is my first zenith ordeal. Any input will be appreciated. Thanks
