Send a message via Skype™ to hangar21
911 bolt-in roll bar padding
Guys,
Please provide information for roll bar padding. I have finished fabricating a bolt in roll bar(87 911 cab) & rear seat delete box. I am currently restoring the enteiror and would like everyone input for roll bar padding.
Thanks in advance,
Terry
Old 10-21-2011, 05:47 PM
"O"man(are we in trouble)
widgeon13's Avatar
Try these guys:
Pegasus Auto Racing
https://www.pegasusautoracing.com/
Old 10-21-2011, 06:40 PM
Walt Fricke's Avatar
Generally you shouldn't need padding on a roll bar. It is behind your seat, so your head ought not to be able to hit it.
But if you do pad, do not - repeat not - use the inexpensive soft foam. It is colorful, but useless in preventing injury. On impact it will simply compress and split.
So use the hard foam half sticks. No real need to pay the premium for SFI rated stuff, but use this crushable foam stuff. It has a peel off adhesive back, which must be supplemented with tie wraps lest the hot sun cause the stuff to fall off the bar.
Old 10-21-2011, 08:01 PM
Northern Motorhead
wildcat077's Avatar
Longacre Racing sells the approved padding for roll bars ... I use it to line up my harnesses on the bar instead of collars and although the padding is self adhesive,i also use tie raps like Walt suggests.
Cheers !
Phil
Cheers
Phil
89 Coupe,Black,95 3.6 engine and the list goes on ...
1983 944 SP2 race car PCA #96
Old 10-21-2011, 08:20 PM
efhughes3's Avatar
I'd definitely pad the parts not covered by the seats. Who knows, flailing arms in a rollover, or something.......
And definitely the SFI stuff as noted by Walt.
Ed Hughes
2015 981 Cayman GTS
6 speed,Racing Yellow
Past:1984 911 Targa (Ruby), 1995 993C2 (Sapphire), 1991 928S4
Old 10-21-2011, 08:52 PM
