Can a Carrera windshield with built in antenia be installed on an SC? Would the recemption be up to par with the cleaner lines?
Thanks, Rich |
I did not do it in my 77 911, But I wished I would have. THe people I spoke with told me it would work no problem.
------------------ Greg-slant/cab http://www.geocities.com/gregslantcab/ |
At the very least you will need the stock Carrera antenna amplifier, but you might get better results with a higher-end aftermarket antenna amplifier/booster.
-Eric |
Senior Member
Yes, you need to make the hole for the cable, it has some 18mm diameter and is a handwide ahead from the right A-pillar on the edge from dashbulkhead. Maybe I find a pic somewhere. Grüsse |
