Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > Porsche 911 Technical Forum
too many projects 1983 sc
56 nomad's Avatar
exhaust valves open?
hello,
I know many of you know this info by heart...i do not so i am hoping i can get pointed in the right direction.
will someone tell me where i can find information about the 911 valve train....more specifically i would like to know which exhaust valves are partially open as the engine rotates in the cylinders. i want to better understand the compression of the intake and exhaust cycle.
looking for some light reading.
regards, ben
Old 10-18-2011, 07:12 AM
Tim L's Avatar
HowStuffWorks "Internal Combustion"
Tim Lynn
84 911 Carrera
PCA E Stock #278
Old 10-18-2011, 07:29 AM
56 nomad's Avatar
Originally Posted by Tim L View Post
Tim,
thanks for responding ...let me ask the question another way ( same way?) as i understand how the internal combustion engine works but am trying to get a handle on the sequence of the cycle (combustion and ehaust). for example at tdc number 1 cylinder both valves are closed before combustion...in cylinder 6 (after 1 fires) exhaust closed intake beginning to open (drawing in fuel and air for combustion stroke etc. etc.
in the other cylinders which exhaust valves are beginning to open or are closed etc.
hope i made it clearer and not more confusing, ben
Old 10-18-2011, 08:21 AM
Tim L's Avatar
it's the same in all cylinders it just happens in the sequence of the firing order of the engine in question. in a 6 cylinder there are two cylinders at top dead center at a time one is in compression and one is in exhaust then at 120 degrees of crank rotation the next two are up.... the firing sequence will tell you the order
Tim Lynn
84 911 Carrera
PCA E Stock #278
Old 10-18-2011, 08:52 AM
Max Sluiter
Flieger's Avatar
Do you want the valve timing for an individual cylinder- like the overlap? That info is in Porsche 911 Story by Paul Fere. The firing order is 1-6-2-4-3-5 I think.
911S
1971 chassis, 2.7RS spec MFI engine, suspension mods, lightened
http://www.flickr.com/photos/max_911_fahrer/
Old 10-18-2011, 09:05 AM
T77911S's Avatar
the only way i can think to answer it is starting with #1TDC, starting its power/down stroke after combustion.
you would also have to know what the cam timing of the motor you are talking about, IE when the valves open and close, if you wanted to be exact as far has how open/closed is a valve.
since one cylinder fires every 120 degrees of crank rotation,
#1 is TDC, the spark plug has fired, combustion has/is taken place and the piston is starting its power stroke, both valves closed.
#6 would be at 240 degrees, both valves are closed and it is on its compression stroke.
#2 would be at 120 degrees, and on the intake stroke with the intake valve open.
#4 would be at TDC, valve overlap (which is where cam timing is set), and it has just completed its exhaust stroke and begining its intake stroke. with most cams, both valve are slightly open with the exhaust closing and the intake opening.
#3 is at 240 degrees and on the exhaust stroke. exhaust open.
#5 is at 120 degrees nearing the bottom of its power stroke, both valves closed.
hope this helps.
start at TDC and work CCW in firing order.
86 930 42kmiles [__] RUNNING:[__] NOT RUNNING: ____77 911S widebody: SOLD
88 BMW 325is 200K+ SOLD
05 BMW 330CI 130K:: [__] RUNNING: [__] NOT RUNNING:
08 VOLVO V70 190K:: [__] RUNNING: [__] NOT RUNNING:
90 B2200[__] RUNNING:[] NOT RUNNING:__2000 MER E320 WAGON [] WRECKED:[]RUNNING:
Old 10-18-2011, 09:06 AM
56 nomad's Avatar
hope this helps.
T77,
exactly what i was looking for....i guess i could have figured it out, thanks for helping me save my few remaining grey cells! let's close the thread.
thanks again and regards , ben
Old 10-18-2011, 11:05 AM
HawgRyder's Avatar
Send a message via ICQ to HawgRyder
Internal Combustion Engine.....Suck...Squeeze...Bang...Blow.
And there you have it.
Bob
Bob Hutson
Old 10-18-2011, 01:07 PM
db_cooper's Avatar
Combustion Chamber - YouTube
Whats missing from the video is the scavenge stroke..
Old 10-18-2011, 01:28 PM
Copyright 2018 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
