Grinding fuchs ??
hi. I'm grinding my fuchs wheels 7x16 so they can be polished but there is some salt corrosion in aluminum, now my question is, how much can I grind (they now measures 4.5 mm in thickness on the horizontal location ??
(I'm afraid they might become too thin in goods) regards. John Last edited by jeos; 10-26-2011 at 12:32 PM.. |
Flat Six
1) Grind until corrosion disappears
2) Polish 3) Mount then drive 4) Crash due to catastrophic wheel failure 5) Kill self, passenger, pedestrians, other motorists 6) Have estate part out 911 in feeble attempt to compensate victims or Send to professional or Purchase replacements If you're going to be foolish enough to do this yourself, please don't troll here for potential co-defendants. Take the risks on your own. Maybe I'm getting grumpy in my old age, but IMHO this is ridiculous bordering on criminally negligent.
Dale 1985 Carrera 3.2 -- SOLD 2026 Jaguar F-Pace / 2025 Ford Bronco Sport |
regards John |
Less brakes, more gas!
I think the word 'grind' is not the word you are looking for. The word you might be wanting to use is sand. Grind implies the removal of a lot more material.
I would sand down the whole wheel and see where you have corrosion left. Then focus sand those spots and see if you can get it to where you are happy. There are several threads here on how to re-finish your wheel to professional quality so do a little searching and you will get lots of info. As for thickness spec., I would say the wheel is useless if you have to grind it to get the corrosion away. If you have curb rash you can use a light file to repair or tone down the rash. -Michael
Michael ![]() '82 Euro SC 'Track Rat' 22/29 Hollows, 22/22 Tarrets, Full ERPB F/R, Rennline Tri Brace, Glass bumpers, Pro 2000's, 5 pts, blah blah blah '13 Cayenne GTS |
Flat Six
Anyone who provides an answer to this question potentially invites implied liability for the outcome ("geez, Flat Six said it was safe to grind down to 3mm but now my wheel's ruined and my car's totaled -- I'm gonna sue . . ."), not to mention the potential liability of PParts corporately and personal liability of Wayne and individual forum moderators (who, plaintiffs will argue, knowingly promoted the sharing and archiving of dangerous and potentially deadly advice). Including 'YMMV' in a response ain't gonna hold up in court. I understand others have done this and you're just looking for some advice. I'm not trying to be an a**hole, but sometimes the enthusiasm for our projects and this community's expertise and willingness to share it can take us down a path of unintended consequences and unforseen risk. Perhaps you'd get better response (e.g., answers to your actual question) if you request responses via PM instead?
The Dude abides...
Flat Six - Certainly you're not implying that something stated on a self-help forum could be admissable in a court of law, are you? That would be right up there with the Ozzy Ozborn lawsuit vis-a-vis teen suicide...That's just crazy!
Lighten up Francis.
Christopher Mahalick 1984 911 Targa, 1974 Lotus Europa TCS 2001 BMW 530i(5spd!), Ducati 900 SS/SP 2006 Kawasaki Ninja 250, 2015 Yamaha R3 1965 Suzuki k15 Hillbilly, 1975 Suzuki GT750 |
When I do something I usually do it so it keeps tollerance,
I just thought that perhaps there were some who havede target rim edges (+ / - tollerance), because when they were produced locally at the factory there was (+ / - tollerancer ) and I will be 100% sure that they keep the minimum goal. There is a book about this topic?regards John |
You will know when you've gone too far. Have you removed the clear coat already?
There must be some who have knowledge about these thicknesses?
Poor guys asking for advice on rims, not legal advice... Gimme a break! Grumpy guy, go take your Porsche for a spin, you'll feel better..
+1 Probably one of those guys that never goes over seventy on public roads. We are on a 911 forum, correct?
if its light corrosion just sand it out and polish it, i dought the corrosion is bad enough to destroy the wheels, Kevin
Take as little as possible. Use the oven cleaner method to get the anodizing out. I have used flap wheels to strip outer rims, but obviously you need to stop as soon as possible, and use the least abrasive grit possible to do the job.
Consider that the corrosion has already taken some of the material, most likely not a lot. |
