02 911 headlight problem
High and low beams do not come on. There is power to them and all other lights work. The bulbs are not the problem nor are the fuses. High beam comes on when using the flash pass . can anyone help?
1982 or 2002?
If it's an 82, it could be your turn signal stalk. If it's an 02, I can't help you as this is the air-cooled 911 forum and we don't use the same type of headlights, obviously. |
+1 what Wayne said
| All times are GMT -8. The time now is 09:14 AM. |
