915 will not shift into gear at idle - shift coupler, clutch adjust, ?
Hello,
I have a 72 with an 85 euro drivetrain (915 with cooler, 85 euro 3.2). About 1.5 years ago I got a Wevo shifter and coupler. Now the car will not shift from neutral into gear when at idle. I can shift delicately when the car is moving between gears. Shift coupler? Clutch adjustment? ? TIA, Scott |
Does double tapping the clutch help? I had issues with shifting into first from idle. I often had to double or triple tap the clutch to spin into a better placement to get the ring over the dogs teeth. When I opened up my transmission I found I was missing one tooth, had all of them worn, my synchro's were shot, and I was missing a large section of metal off a breakband.
I am not saying that this is your problem, it just happened to be mine and is a possibility. I'm hoping your issue is a simpler fix! |
If you're getting gear clash/grinding when attempting to shift you will have a clutch release problem. A breaking clutch cable is a possibility, and so is a breaking throw out bearing release fork. (This assumes that everything is assembled properly, nothing is loose, etc.)
Before committing large sums of cash, remove the rear tunnel access plate and check the shift coupler for excessive play. if okay, remove the shift housing assy. and check the nylon bushings in that area: end of shift lever and front of shift tube.
If okay, proceed with the other diagnosis described. Easy stuff first. Sherwood |
It is shifting into most / all gears at idle from neutral. There was a new clutch put in maybe 2 years ago and I think a new cable.
Scott |
"......the car will not shift from neutral into gear when at idle." Fixed? Sherwood |
I would check the clutch cable travel distance is within spec.... 25mm.
Sorry, replied with additional info too quickly.
It is NOT shifting into most / all gears at idle from neutral. There was a new clutch put in maybe 2 years ago and I think a new cable. |
It is shifting into most / all gears at idle from neutral. Witch way is it?? If it does not shift into gears at idle: "clutch release problem" Start with the easy stuff first. Clutch pedal free play to much? Cable integrity-loosing a few of it's mutable wires wound together to work effectively? Next most likely release fork. Has the car been sitting for a while? Disk could be "Rusted" to flyheel and/or P-Plate. |
I can move the shifter and feel the gears when the engine is off. In fact, this is the way I have to shift into reverse to back the car out (engine off, shift into reverse, start engine, back car out). Then turn engine off to shift into first or second, start car to drive around. Did make a shift from first to second when driving (not at a standstill at idle where shifts grind).
Hope this helps. TIA |
Hope this helps.
Yes! You have a clutch RELEASE problem. Not a shifting problem. See; "Start with the easy stuff first"................. |
It was the clutch cable. Had a bunch of slack in it. Unfortunately, after the mechanic adjusted it, the engagement point is way too high. The shop said they could try to do a fine adjustment but gave me a heads up it might be time for a new clutch cable.
Thanks everyone, Scott |
| All times are GMT -8. The time now is 03:01 PM. |
