Horn Button question.
Is there anyway to use a Double Contact horn Button (momo or similar) on our Single contact 911's? I have a double I want to use and wondering is I can easily wire something to make the horn work.
thanks in advance. JIM |
Do you have a pic?
There should Contact ring with an extra spade fitted onto the back of the original hub which comes into contact with the side of the momo horn. This Pic shows it quite well. I had the reverse problem when I reinstalled a Porsche button on ma Momo wheel
http://forums.pelicanparts.com/uploa...1319525430.jpg |
http://forums.pelicanparts.com/uploa...1319527453.jpg
So if the second contact can be linked to the ring it might work? I can try that. |
Thats basically it. The contact to the side needs a simple grounding point on the steering column
Thanks! you rule!
| All times are GMT -8. The time now is 03:13 AM. |
