Top gear whine
There is a mild whine when in 4th(top) gear in my 930. Stops when foot lifts off gas. Shifts fine,no grinding.
What is it, Fix it, or drive forever? who even repairs 930 transmissions if I chose to ship it? |
Is the whine a recent occurence? Ho w many miles on the drivetrain?
Sometimes, as the bushings in the linkage wear they can cause the shifter to be out of alignment slightly. Have you adjusted your shift coupler recently? If not, I would at least check out the bushings at the linkage joints for wear. Replace as needed and adjust your coupler. My 5th gear will whine sometimes. I do not intend to worry about it. John Walker is who I would recommend to rebuild the gearbox if you don't do it yourself.
1981 911SC ROW SOLD - JULY 2015 Pacific Blue Wayne |
Car is new to me, 90 k miles,
Using redline trans gear oil, all shifter coupler/ bushings new. When moving the shifter the noise does not change. John Walker ,I did not know he did transmissions also. |
At first, I thought you were referring to complaints about the TV show, Top Gear, US version.
never mind. Sherwood |
Sherwood-I thought the same thing.
![]() I lifted this thread fromthe 930 forum-http://forums.pelicanparts.com/911-930-turbo-super-charging-forum/483542-930-gearbox-whine-normal.html
Those guys do whine a hell of a lot, but it's probably the R&P.
72 911 Although it is done at the moment, it will never be finished. |
