Another: Where does this go thread
Hi, I'm just in the middle of working on the front trunk area and am needing to know where the heck the 3-way brake splitter bolts up. I'm referring to the one for the front calipers. I'm making my own brake lines so I have nothing to go by. It should mount somewhere near the fuel pump I would guess.
A photo would be divine. I've looked and looked but can't find anything. Thanks a bunch. Derek |
On my RHD there is a tab in the steering rack tunnel. The coupling mounts to this via a bolt (M6 from memory) - the nut is part of the tab.
My brake lines are not installed in this pic but the tab is circled. http://forums.pelicanparts.com/uploa...1319516317.jpg |
Thanks, that helped. Mine is def. different but it got me thinking if there were an easy way to attach it to the plate that covers the pedal box hole, it would be perfect. It turns out there is a mounting tab on the plate for the 3-way splitter. Perfect! Thanks
| All times are GMT -8. The time now is 04:57 AM. |
