UNISYN Question
Trying to balance the carbs(PMO),and I cant get the the ball to float half way up the Unisyn gauge. It seems so easy, but no luck for me, I can parctically do everything on my car but balance carbs. Is there a way to check to see if my unisyn is broke. IF I unscrew the disk any farther than it will fall off in the carb.
PLEASE HELP ME. Im about to take a shotgun to it. Thanks Eric |
Eric,
If you want the sensitivity to increase ... you ar going the wrong way! Screw the disk IN to get the ball to RISE! |
| All times are GMT -8. The time now is 10:19 PM. |
