The whistling doesn't annoy you? I put a stock airbox lid back on after a listening to the whistle for a few weeks. What seems odd to me is that i have removed airbox lids on several other cars and there was no whistling, does everyones AFM equipped 911 sound this way?
I wonder what is the amount of opening in the air box to get the advantage before it becomes overkill. I use my SW chip, B&B 2 in/1 out, and this cover to get the stock look with more air flow:
http://forums.pelicanparts.com/uploa...1319916566.jpg My thought is that the horn is the greatest restriction so I'll have at least the same volume of airflow but with a direct path. |
I also got whistling after cutting off the entire face of the airbox. At first I was disappointed that this was part of the "great" sound everyone talked about. But once it got going the sound was pretty cool. I've gotten used to the whistling and I can't even hear it with the radio on.
I also washed my car before changing the box. It didn't seem like water would be a problem but I would still recommend being careful. |
Aha! That's my problem, i don't have a radio. |
Well some people compare it to the sound of a turbo. So just tell people that's what it is and since its bring in a whopping 5 horses it works almost as well ;)
From perception comes reality- If I sound fast I'm fast... but before I start drilling holes or buying new performance covers must I also get my SW chip redone to take advantage of the increased air volume?
Thanks Carl |
In order to do this properly, the air/fuel ratios need to be corrected to the same ratios for each test, eliminating that as a variable. The stock chip runs lean at the low and mid rpms, and very rich at upper rpms. If I for example, with the stock chip, take off the airbox cover and measured a gain of 8 hp at 6000 rpm, but the AFR there also leaned back from 11.5:1 to 12.3:1, well how much of the power change would you attribute to the airbox cover vs the leaning of an overrich air fuel ratio? You see a test like that does not achieve the objective and becomes subject to debate because of it's flaws. Quote:
Dynojet Automotive Dyno Centers But before you do that review the basic instructions here and contact me with any questions: http://www.911chips.com/Dyno instructions.pdf Quote:
Thanks for the answers Steve!
What are everyone's thoughts on the statement below (from a prior post on airbox mods): "The "horn" was to provide a clear and clean path for "cool" air that was being forced in from the lid vent at speed. The air in the way back of the compartment is warmer and more turbulent. So I think this would be in effect while in motion and not really in effect during idle." So maybe there is a gain on a dyno when not in motion, but not at speed with a heat soaked engine? |
| All times are GMT -8. The time now is 12:52 AM. |
