69 Targa will not run...CD system is bad??
I have a 69 911 Targa with an off brand (Mark V) CD system that I think has failed. I am looking to replace this with a Bosch CD system.
My question is this - currently the car has the antiquated Marelli distributor (I know...this needs to go at some point too) Will the Bosch CD work with this distributor or do i need to change this out all together at the same time? Thank you for your input! |
the bosch CD will work, if you wire it up like a car that came with it. see a wiring diagram for up to 1977. no condenser in that system, so remove it from the distributor if there is one attached. usually the mark V units have a switch somewhere that allows you to go back to coil/condenser if the unit fails.
| All times are GMT -8. The time now is 07:25 PM. |
