-   -   69 911 T Ignition problems - need some help! (http://forums.pelicanparts.com/porsche-911-technical-forum/636591-69-911-t-ignition-problems-need-some-help.html)
69 911 Targa 10-25-2011 08:01 PM
I have an antiquated Mark V ignition CD system that i believe has failed. Does anyone out there suggest the MSD system or the Bosch CD system? Also, if Bosch is the pick, will it work with my Marelli OEM distributor or does this also need to be changed out? Thanks for your help!
