Go Back   Pelican Parts Technical BBS > 1- Porsche Technical Forums > Porsche 911 Technical Forum
Canucks Fan
Question Window tint removal??
I have tinted side and back windows and I want to remove the film tint thats on the inside of the windows. Is this a tough job? Has anyone done this on their windows and did you have trouble or any thing I should watch out for? How did you do it, just scrape it off?
Any help would be great
Finn
From the Deep Dark Jungle
Old 10-26-2011, 10:41 AM
  Pelican Parts Technical Article Directory    Reply With Quote #1 (permalink)
Ruby911
ruby911's Avatar
I used a garment steamer and it was VERY easy. Just steam the film and after a few minutes the stuff will peel right off and leave alomost none of the glue behind. I believe if you just start pealing without steam (or some other prcoess) it will leave a lof of glue residue that can be a pain to get off.
Good luck
1984 Carrera - SW Chip, Factory Short Shift Kit, Cat Bypass - SOLD
1968 Ossi Blue 912 Sunroof Coupe - SOLD
1971 911E - 2.7 Twin Plugged, PMOs - SOLD
1965 356C Outlaw
RGruppe #577
Old 10-26-2011, 10:54 AM
  Pelican Parts Technical Article Directory    Reply With Quote #2 (permalink)
schumicat's Avatar
it is pretty easy with a scraper. I think I used ammonia to get rid of glue residue very easily. goof-off would probably also work on the residue.
1982 911SC, Mocal oil cooler, Bilsteins, Carrera tensioners, backdated heat, factory short shift, Seine gate shift, turbo tie rods, pop off.
2005 Mercedes-Benz C230 kompressor sport 6-speed (daily driver)
Old 10-26-2011, 11:13 AM
  Pelican Parts Technical Article Directory    Reply With Quote #3 (permalink)
Burn the fire.
Brando's Avatar
If you were local I would just ask if you want to trade windows... I'm looking to get all mine done before the end of the year...
That said, a scraper works best. A razor blade may be helpful, careful of the sharp edges. Some 3M adhesive remove to soak the 'stuck' areas will help a bit.
[x] Ridable | [_] Broken: 2017 Victory Octane
"Drive it like you stole it."
Old 10-26-2011, 12:06 PM
  Pelican Parts Technical Article Directory    Reply With Quote #4 (permalink)
JoeyD911's Avatar
Spray the inside of the window with soapy water, place black plastic film over the solution, again on the inside of the window. Use either a heat gun on low to warm the window from the outside or set it out in the sun all day. The film will peel off so easy you'll wonder how it stuck in the first place. The sun trick works better in the summer or when the temp is over 80 degrees. Being in BC you may want to use the heat gun method. Make sure you keep the heat gun moving, don't heat one section of the glass more than the others or bad things can happen. This is the only way to strip window film without chemicals or risking cutting or damaging something with a scraper.
Joe D
L.I. NY
82 911 SC 3.0
Swartzmetalic
Old 10-26-2011, 12:21 PM
  Pelican Parts Technical Article Directory    Reply With Quote #5 (permalink)
1986911's Avatar
Check out my old post. Steaming all the way!!
I am a believer, steam those tints off!
MG---1986 911 TARGA, SSI'S, STEVE WONG CHIP, M&K EXHAUST, ELEPHANT RACING GOODIES + TRU DESIGN CUSTOM FUCHS
1989 930 FACTORY SLANT NOSE -- RARLYL8 EXHAUST, K27 7200, TIAL 46MM, 0.9 BAR SPRING, GARRETSON INTERCOOLER , LEASK WUR, WEGO IV AFM AND NHS BOOST GAUGE.
2012 DODGE RAM 3500 LONGHORN 4X4 "EVERYTHING BUT THE KITCHEN SINK"
Old 10-26-2011, 02:19 PM
  Pelican Parts Technical Article Directory    Reply With Quote #6 (permalink)
Now available:  101 Projects for Your Porsche Boxster!
motorcop's Avatar
Razor blade and windex. Will come right off.
Old 10-26-2011, 02:30 PM
  Pelican Parts Technical Article Directory    Reply With Quote #7 (permalink)
Jonny042's Avatar
I did this to a caprice wagon. Approx. 1/2 acre of glass. Peeled, then windex to remove the residue, as quite a bit of glue stayed behind.
So in other words use a steamer!
Old 10-26-2011, 03:12 PM
  Pelican Parts Technical Article Directory    Reply With Quote #8 (permalink)
The Mighty Pieholio
Bob Kontak's Avatar
Razor blade rocks if you don't have a rear defrost.
If you do, heat gun or the steam method - biased towards steam.
1/2 acre on a Caprice wagon? That is conservative.
Old 10-26-2011, 08:40 PM
  Pelican Parts Technical Article Directory    Reply With Quote #9 (permalink)
loose nut behind wheel
cudabnu's Avatar
I used a steamer, worked great!
80 911sc/993 GT-2 body/3.6L motor
71 VW Convert (300 hp 2332 FI turbo)
97 Passat TDI 320K miles and counting
Old 10-26-2011, 09:58 PM
  Pelican Parts Technical Article Directory    Reply With Quote #10 (permalink)
Canucks Fan
Thanks guys, I'm adding this the the winter list of "stuff to do"
Finn
Old 10-27-2011, 02:56 AM
  Pelican Parts Technical Article Directory    Reply With Quote #11 (permalink)
Ruby911
ruby911's Avatar
One more tip...the warmer the temps outside, the quicker the job will go. Yoo may not want to wait until the dead of winter.
1965 356C Outlaw
RGruppe #577
Old 10-27-2011, 04:35 AM
  Pelican Parts Technical Article Directory    Reply With Quote #12 (permalink)
Now Available for Ordering:   101 Projects For Your BMW 3 Series 1982-2000  [more info]
1986 Targa 1972 RS clone
magnuskgc's Avatar
if you have to do the rear window with the defroster use a scotch brite pad or steel wool with an amonia solution.
Old 10-27-2011, 02:08 PM
  Pelican Parts Technical Article Directory    Reply With Quote #13 (permalink)
I agree with the above "steamer" post. I tried the ammonia and the simple green method in the sun..did not work for me. Then i used my wifes clothes steamer from Costco and it was a breeze.
Old 10-28-2011, 10:12 AM
  Pelican Parts Technical Article Directory    Reply With Quote #14 (permalink)
ivangene's Avatar
how about a heat gun and warm it up?
I seriously JUST sold my steamer on craigslist because I never found a use for the thing!!
Ed M
86' Coupe
Old 10-28-2011, 01:16 PM
  Pelican Parts Technical Article Directory    Reply With Quote #15 (permalink)
Roby466's Avatar
I just did this on my 911 to pass provincial inspection.... A funny enough solution that worked great was to use a heat gun (or hair dryer) to heat up just a bit the window and peel the tint. Some (a lot) of glue will stay there but if you spray soapy water (I was told to use baby shampoo and warm water) it comes right off with a razor blade. Really easy actually. Apparently when you put window cleaner, it makes the glue harder to remove. I did not try as it was pretty easy with the shampoo solution.
I would be careful over the defrost elements in the back, I did not try there but could the razor blade damage them? Perhaps using a towel with the solution would work.
1985 Black 930, K27 7006, Garretson Intercooler, Adj boost, TB: 23 - 31mm, bielstein sport shocks, ER polybronze bushings front and rear, ER monoball joints front and rear with offset camber plates, 935 X triangulated strut brace, raised spindles, racing bump steer kit
1981 Black 911sc (sold)
Old 10-28-2011, 06:27 PM
  Pelican Parts Technical Article Directory    Reply With Quote #16 (permalink)
Halm's Avatar
Used a steamer for tint removal today on the 996. Worked pretty much as others have said. It took me about 2 hours on a 55 degree day to do all 5 windows.
I would make a couple of suggestions. 1.) have a few new single sided razor blades available. You will need them at some point. 2.) wear a protective glove when steaming, especially the back window. 3.) a can of 3M General Adhesive Removal might also be handy.
'80 SC "Measles"
'13 Cayenne
'85 RX-7 GSL-SE (Sold)
Old 10-29-2011, 01:54 PM
  Pelican Parts Technical Article Directory    Reply With Quote #17 (permalink)
"farking Porsche hero"
Rich Lambert's Avatar
This thread finally got me to tackle something I've hated about my car and put off fixing for 5 years. When I got the car all the windows were tinted. I replaced the door windows, but never got around to the rear quarters and the back window. Wow, what a huge difference! I used a $25 garment steamer I got from Target.
Before...blue tint
After...clear!
I'm liking the new clear look...wish I'd done it 5 years ago. Thanks for the inspiration!
Rich
'66 911 #303872
'07 Cayman
'58 Land Rover S2 88"
Old 11-06-2011, 03:21 PM
  Pelican Parts Technical Article Directory    Reply With Quote #18 (permalink)
Looks great
Old 11-06-2011, 03:23 PM
  Pelican Parts Technical Article Directory    Reply With Quote #19 (permalink)
Copyright 2017 Pelican Parts LLC - Posts may be archived for display on the Pelican Parts Website -    DMCA Registered Agent Contact Page
