-   -   Engine update (http://forums.pelicanparts.com/porsche-911-technical-forum/63678-engine-update.html)
Matt Holcomb 03-24-2002 03:50 AM
Engine update
John Gregory decided that the time was right to put the car on the dyno, so we did -- on Friday.
It wasn't long before it became apparent that the engine was getting too hot too quickly. Friction, and lots of it. It's still warm down here, and while the engine has hit 100C (during spirited runs) on a few occasions since it was put back together with the 10.5:1 JE pistons (the actual CR is closer to 11.1:1 than 10.5:1) and the GE-60 cams, I was pretty sure that the high engine temps had more to do with ambient temperature and a still-fresh engine than a compression ratio that's too high.
In a fortnight we'll be taking the heads off so that we can reduce the compression ratio. Thankfully, John is considering this "part of the job", as it's the first time he's rebuilt an engine with non-German, high-domed pistons. He wanted to see if he could get away with that compression ratio, and to his credit, he came close -- very close. We could leave the engine as it is, and it would be fine for spirited street use. However, since the engine is going to be raced, we have to reduce the compression ratio (by modifying the pistons) down to 9.8:1 to make sure it can be raced for a few seasons.
In case some of you are wondering what sort of power the engine is currently developing (I know there's a few of you!) we were able to get one reading (at only 6,000rpm) before the engine reached 100C:
<b>220bhp, at the flywheel.</b>
Not brilliant, I know. We're a long way from our lofty claims of 260-270bhp, but the engine was only going to develop that sort of power with modified stacks, a special exhaust system, and after 8-10,000kms of use. With a compression ratio of 9.8:1, 260-270bhp is now impossible without modifying the heads. But I'll be happy with 240-250bhp, and John won't be satisfied until the engine is developing that sort of power after the necessary modifications are made.
Matt Holcomb
1974 911 Carrera 2.7 RoW<a href="http://www.holscope.com/74Carrera2.7" TARGET="_blank"></a>
1975 Mercedes-Benz 280SE
<a href="http://www.holscope.com/74Carrera2.7" TARGET="_blank">Dedicated Homepage</a>
<a href="http://www.holscope.com/74Carrera2.7/rebuild" TARGET="_blank">Engine Rebuild Homepage</a>
<a href="http://www.cheaterswayside.com/911/gallery.asp?sort=0&userid=127" TARGET="_blank">Porsche Owners Gallery Profile</a>
<a href="http://www.pelicanparts.com/cgi-bin/pmpre/pm.cgi?action=display&login=Matt_Holcomb" TARGET="_blank">Pelican Gallery Profile</a>
jluetjen 03-24-2002 10:51 AM
I must of missed something here...:confused: What is the John's engine spec? Engine size? Fuel System? What kind of fuel were you using?
This sounds intreguing. I always love to see real data. BTW; what did the HP curve and torque curve look like using the GE60 cams and the race compression pistons? I'm thinking of using a similar configuration when I convert my car to track only use in the "near" future. Since it will be a competition car, I'm torn between going all out with a GE80 or using the less wild GE60.
Thanks for sharing!
Matt Holcomb 03-24-2002 02:09 PM
John,
We rebuilt my 911/83 (2.7) engine. The fuel system is MFI. As for the type of fuel used, we have a couple of 98-octane fuels in Oz. I like Shell Optimax.
The HP and torque curves were as you would expect from the GE-60 cams, but the high engine temps meant that we had to predict the curves above 6,000rpm.
Matt Holcomb
Early_S_Man 03-24-2002 04:48 PM
Um Matt ... about that power level ... nothing to apologize about there! You were, by my estimate ... AT LEAST 300 - 400 rpm BELOW the power peak! So, it may very well already be making 240 - 250 hp ...
Had you planned, or have you already changed to a synthetic oil? That might help the high temps a bit! Of course, a bigger cooler, fan, etc. in the right fender might help, too!
Adam 03-24-2002 06:49 PM
Matt,
I have to say that 220bhp surprises me. I expected it to read much higher, given my tried and trusted "Seat-of-the-pants" dyno! ;)
Seriously, I am surprised that it's heating up so much, given it's temprement on our Pelican Drive Day.
Bill Douglas 03-24-2002 06:57 PM
Matt, I know you would have checked all the obvious things.... But could it be something like oil not circulating properly due to a valve in bac-to-front or something similar. It just seems a shame to pull the engine to bits again. Bill.
CamB 03-24-2002 07:08 PM
So is it getting too hot from detonation Matt? I'm guessing John Gregory has seen enough to know if there is a correctable cooling issue.
Could you find some race gas and try running it on that, just to check ;)
Otherwise, I hope the work to get it down to a nice reliable c/r is successful.
Oh, another thought - if it is detonation, could you twin plug it (I like using other peoples cheque-books).
Cam
Matt Holcomb 03-24-2002 11:01 PM
Warren,
Detonation at full throttle meant that we had to severely retard the timing, but in doing so it caused the engine to run hot. On the dyno, the engine raced to 100C before we could get a maximum power reading. With the engine temp at 100C and climbing, a reading at 6,400-6,800rpm would have probably shown an increase of only 5-10bhp; we couldn't get ahead of the dyno, if you know what I mean.
I'm going to be upgrading to a radiator-style cooler, but if we leave the engine alone, it would have a negligible cooling effect given how much we have to retard the timing to stop the pre-ignition.
Adam,
I'm surprised, too! But, a standard RS Touring is still a pretty quick car. :)
Now we know why I had trouble keeping up with the front-runners during our convoy! I didn't think shot front shockers would make the car <i>that</i> much slower!
Bill,
It's the pre-ignition that makes another tear-down unavoidable.
Cam,
Reducing the CR to 9.5:1 should do the trick, and will be cheaper than twin plugging it. Man, if only I had more cash to take advantage of this free tear-down!
Matt Holcomb
Rufblackbird 03-24-2002 11:43 PM
Matt,
Having heard what you've done to the engine so far from Adam earlier today, I'm surprised, too, at "only" 220hp, as I believe a stock MFI Carrera was rated at 210hp.
What will be done to the pistons so that they will reduce the compression ratio? And wouldn't that mean less power?
Wayne 962 03-25-2002 01:35 AM
What octane were you running? If you've come this far, I would go with twin plugs and an electromotive distributor-less system. At least you don't have to buy a 12-plug distributor...
Probably cost you about $1500 (the head work is really not that expensive) - the electromotive stuff is only $1100...
-Wayne
Matt Holcomb 03-25-2002 04:17 AM
Jeff,
John is going to machine the pistons and add an extra spacer to each cylinder to lower the compression ratio.
Heat is power's enemy, and if we don't twin plug the car, or do what Wayne has suggested, then a lower compression ratio will make the engine more powerful as there won't be any excessive friction and pre-ignition.
Wayne,
I only use 98-octane fuel. Can you tell me more about the electromotive distributor-less system?
Matt Holcomb
CamB 03-25-2002 01:10 PM
Matt
Electromotive have a website:
http://www.electromotive-inc.com
Also, Steve Weiner @ Rennsport Systems has put together some really useful info on twin-plugging options at:
http://www.rennsportsystems.com/~porsche/2a.html
http://www.rennsportsystems.com/~porsche/2f.html
Steve is the man on ignition...
Your usual problem will be the Australian Peso. Just be glad you aren't a Kiwi. Electromotive looks like it needs a crank sensor arrangement (and the alternatives for sale are absurdly expensive), two ignition packs and headwork to accept the extra plugs. It will be pretty expensive...
Lots of research if you have the time!! Good luck.
Cam
Wayne 962 03-25-2002 01:48 PM
http://www.emi.cc/
Richard Clewitt is our supplier for the Electromotive products. Feel free to give him a call, or visit his website. He will (hopefully) send you back to us for the sale if you decide to go with that option:
http://www.clewett.com/
It seems expensive at first, but if you add up all the other costs (like a twin-plug distributor), this system is much, much better...
-Wayne
CamB 03-25-2002 02:06 PM
Another option that probably won't work for you uses a 964 distributor.
I know the 964 twin dizzy can be made to work with an SC case (but I don't know how! I will have one in a month or so though). I don't know if the same applies to a magnesium case, but I suspect not or it would be more common. Wait, I reread Steve Weiner's stuff - it will work. This seems much cheaper to me. Seems to me you need twin plugged heads, modified distributor (only a few hundred??) and 2 CDI boxes (or 2 MSD boxes or equivalent). This looks like US$500+ cheaper.
Maybe someone can give more details on how this conversion works.
Cam
john walker's workshop 03-25-2002 03:45 PM
so what's wrong with 100°C? that's 212°F. lots of cars run 210-220° normally. 250° and above is trouble, but if you had a cooler with airflow you might be allright. you should run it some more and see if it hits 250°.
Matt Holcomb 03-25-2002 04:34 PM
Cam,
I'd love to twin plug it! Somehow, I don't think I'll be able to afford it! Same with the Electromotive distributor-less system. Oh well. With a lower compression ratio, we'll at least be able to play with the timing to find more power; 240-250bhp is plenty for a car that only weighs 1080kg.
Thanks for those URLs, though. It was fascinating reading!
Wayne,
I like the Electromotive stuff. Thanks very much for the info. The Australian/U.S. exchange rate just makes it prohibitively expensive.
John,
I agree: 100°C isn't that high, but it's reaching that temperature (on warm days) after only 20-30 minutes of "normal" driving! At the track, and on a warm day, 250°F would be very achievable after three hot laps, even with a radiator-style cooler and a fan.
It's that darn pre-ignition.
Matt Holcomb
CamB 03-25-2002 05:38 PM
Matt
I just had another think about the "cheap" 964 distributor option and I suspect it will have no provision for mechanical advance, so would require something extra for that anyway (ie an ignition computer or full EFI computer).
In other words, it wouldn't be cheaper... unless you were changing induction anyway to EFI, as computer-controlled ignition only would be an expensive add-on.
Or I could be talking out my ass... apologies if anyone reads this and thinks I am full of crap. But there may be a cheaper way...
Is there any way you can get hold of some 100+ octane race gas to test if it still has pre-ignition problems - no long term solution but it would be great to know how it goes.
Cam
Matt Holcomb 03-25-2002 05:52 PM
Cam
Cam,
Sure, I could try a tank of Avgas, but the Porsche Club of Victoria has banned it!
Matt Holcomb
cwood 03-25-2002 10:43 PM
Me think's your building too much cylinder pressure.
Wrong cam for that compression ratio probabely could use a few more degrees of duration just a thought.
964 distributors are $460.00 plus shipping for a brand new one complete with caps and rotors.
A MSD timing computer or one of the new wizz bang ignition sytems they sell should work, some are laptop programable ie the digital 7.
Chris
beepbeep 03-26-2002 10:50 AM
Vanilla MAP-equipped EFI, twin plug and knock sensor will fix all this...those heads ain't the best when it comes to pre-detonation.
SDS is there, it's cheap and it works. Autronic is your local (and pretty expensive) alternative...very advanced. Haltech is old food. Low on cash? Try Megasquirt...
MFI?? Throw it in the river or sell it to some "purist".... :D
CamB 03-26-2002 01:13 PM
Ha! I will answer for Matt on this one - I know he is an MFI devotee and would never change it!!!
Also, funny how there are so many Australasian engine computers - I think MoTeC, Autronic, Haltec, Link (NZ product) and Wolf3d are all high quality local products...
I didn't think about the MSD options... http://www.msdignition.com/2000_1.htm seems to be the one. Summit says about $670.
So would this work? No advance in the distributors, fully map ignition as per MSD instructions?? What about... twin plug = 2 MSD units? That could cause serious $$$ and compatability problems. Could you have one of the programmable 7s and one regular MSD?
I have had a 964 distributor modified for optical pickup for approx US$150. I have no idea what it costs to modify the 964 distributor to the 2.7 case.
I mean, I am really interested in 2 things here:
1. the programable MSD unit might be much better than mechanical advance for carbed, MFI and CIS cars?
2. can this be combined with modifed 964 dizzy to provide cheapish twin plug?
Thoughts???
beepbeep 03-26-2002 04:26 PM
964 dizzy? What's that? A mechanical thing going round and round?? Ohhh...c'mon...it's 21:st century...all modern EFI's use computer-controled direct-fire.
Six wires going to six dual-pack coils...each feeding two spark-plugs per cylinder....no dizzy's, no contacts, no vacuum advance...no nothing...just pull out the friggin' distributor and cover the hole. Advance maps are held in flash-memory and can be reprogrammed at will. Just remember: don't be afraid of technology...!
CamB 03-26-2002 05:45 PM
I agree, but I'm trying to figure out how to do this as cheaply as possible.
Electromotive looks the cheapest (HPV-1 with timing control) - but for instance, a modified crank pulley (which incorporates a sensor wheel) for the Electromotive units is EXPENSIVE, based on the prices I have found. Even if you fabricate yourself it is not inexpensive ($120+). Something will always be required to do this job. And the Electromotive coil packs are $500+ each. 2 needed for twin-plug, remember.
Prices I found were about $1500 total, I think. Now probably I don't know a cheaper way, but think something using the 964 dist could be getting there.
OK, I admit it, mostly I get annoyed by the $500 each for the HPV-1s (no way your average modern 6 cylinder coil pack is $500 to replace) and the modified crank pulley/sensor kit ($460).
I'll go be quiet now :D :D
cwood 03-26-2002 10:17 PM
MSD has DIS systems I would contact them and explain what you are trying to do.
Just a thought.
Chris
Matt Holcomb 03-26-2002 10:25 PM
Cam is right, I am an MFI devotee, and I will never change. I'm driving history. I'm trying to preserve an era. Having said that, I don't exactly have a carbureted Ford Windsor V8 stuffed into the tail of my car!
I still don't think modern electronically-controlled systems offer the same throttle response as an engine with MFI. Of course, I won't be surprised if I'm proven wrong. If, at some stage, I need to rebuild my pump (it's on the cards!), I will shell out $2-4K to do so, knowing full well I could "upgrade" to a more cost-effective EFI system like MoTeC or Wolf.
These alternative, electronically-controlled systems sound like fun, it's just that they don't do it for me. As they say, different strokes for different folks.
Matt Holcomb
Matt Holcomb 03-26-2002 10:35 PM
Chris, Beepbeep,
I'm going to lower the CR to 9.8:1 and then try and make up for the loss in power by doing something to the air-intake system and the exhaust.
Even though I'm an MFI devotee, these EFI alternatives do sound interesting, so thanks for educating me!
Matt Holcomb
cwood 03-26-2002 11:13 PM
Matt
I would contact the cam manufacture and ask them about the detonation issues. Also I would see if they recomend the cam you are using with the compression that you pressently have 11.5:1 or what ever it figured out to be.
Cause it shure sounds like your building to much cylinder pressure. Or run it on #2 diesel then you won't have to worry about ignition systems......hmmm SC Super Cummins not bad not bad.
Well had to throw that in.
I ran my drag car on the street with pump super with out detonation issues. 12.2:1 377cid chevy 10.50's @124 blah blah .
Also did it detonat when slowly accelerated on the dyno pulls?
Because you may also have an advance curve issue that is causing you problems. Or you may be sucking some oil into the combustion chamber. Or you may not be feeding it enough fuel to make it happy. I would put a set of EGT (exhaust gas temperature) sensors on it to see what kind or temperatures you are running.
Besides a bigger cam gives you that nice loping idle with higher compression ratio's.
Well best of luck.
Chris
CamB 03-26-2002 11:26 PM
I'm talking changing the timing only to electronic control - it will leave the MFI part alone and should preserve (or enhance) throttle response.
However, as you say - you are an MFI devotee and want to keep it "period-correct", so this would not be an option.
Cam
Matt Holcomb 03-27-2002 04:16 AM
Cam,
Actually, I don't mind the idea of ditching the distributor ...
Matt Holcomb
