80 911 SC, Orem, Ut
RSWiser's Avatar
Smoking SC
My 1980 SC has been parked for about 4-5 months while I have been working on some items and to be honest, just not getting things done as quickly as I would like.
This morning I decided to take it for a short warm up drive.
My car has a pretty good oil leak that I haven't been able to get to yet.
When I started up it smoked up a storm. I mean a cloud of white smoke. Once I stared driving, by the time I had gone about 2 blocks, no more smoke.
It has always smoked a little on startup after sitting a couple weeks. Always stops after a block or two.
Does this give you clues as to where my oil leak is so that I can get after it.
Over the course of the 5 months sitting I was down about 1/2 quart of oil so I topped it off and went for a longer drive.
Thanks,
Rob
Rob
1980 911 SC
Old 10-29-2011, 12:56 PM
Fleabit peanut monkey
Bob Kontak's Avatar
Oil seeps past valve guides. Don't sweat it.
I am almost certain that it depends on where the engine crankshaft stops (differing arm pressure on exhaust valves) mine is totally intermittent (81 SC with 30k on new head rebuild) and volume of the puff cloud can change from one time to the next and mostly no puff cloud.
Edit - Joe Bob knows more than me but whatever the reason is, I would not sweat it.
Old 10-29-2011, 01:15 PM
P-Car
woywitka's Avatar
Many enthusiasts and experts on here say that cold start smoke is a fairly common and benign quirk of many flat 6 Porsche engines.
If you wish to reassure yourself, you can have a compression and leak-down test performed to see how capable your engine is in terms of keeping oil out of the cylinders.
My SC smokes on cold start, worse in summer, almost non existent in winter. Sometimes it puffs a big one. As long as the engine is not smoking when warm, when pulling away from a stop, or smoking at high revs off throttle (leaking valve stem seals) then I'm told not to worry.
In terms of adding oil, this can be difficult to identify what is leaking (and possibly burning off on exhaust) and what is actually being combusted. Adding a liter every 1,000 miles or 1.600 km is within normal range
Check your spark-plugs for excessive oil/carbon deposits too.
Even a tired 3.0SC engine with a broken head stud, oil leaks, and smoking on cold start have been known to go forever. So it depends who you talk to for advice.
Old 10-29-2011, 01:20 PM
Capitalist and Patriot
911Freak's Avatar
BTDT ^^^^^^^^ what Joe Bob and Bob said...
Don't worry about it, give her the Italian tuneup and she'll be good to go!
Upside is you probably killed a few hundred nasty mosquitoes in the neighborhood!
Former Test driver & Production Manager Singer Vehicle Design
2009 Cayenne GTS, '81 911SC RoW Targa (lot's of goodies), '86 535csi, '84 633 csi (turbo charged-sold) , '68 912 Targa (sold) , '69 911E (sold)
"Dream it, Believe it, Decide it, DO it "
Old 10-29-2011, 01:22 PM
Free minder
Aurel's Avatar
White smoke is water vapor. You must have had lots of condensation water accumulated in your exhaust and catalyst. I bet you it was just water coming out.
1978 SC Targa, DC15 cams, 9.3:1 cr, backdated heat, sport exhaust https://1978sctarga.car.blog/
2014 Cayenne platinum edition
2008 Benz C300 (wife’s)
2010 Honda Civic LX (daughter’s)
Old 10-29-2011, 03:19 PM
Plecostomus's Avatar
If it bothers you....drive it at night....%^b
Normal if it sits awhile....12 quarts of oil tends to seek it's own home. Sometimes past the rings, valve seats and other lubricated area with acess to the combustion chamber.
Ever read up on the SR-71 Blackbird? They had to park them in a catch basin due to the leaks....
They rain kerosene until the metal expands after warming up.
"It looks like a Pleco.."
Old 10-29-2011, 04:05 PM
Bob Kontak's Avatar
Originally Posted by woywitka View Post
Many ..... experts......say that cold start smoke is a fairly common and benign quirk of many flat 6 Porsche engines.
The Bruce says it. That's all I need to hear.
Old 10-29-2011, 04:18 PM
80 911 SC, Orem, Ut
RSWiser's Avatar
Thanks for the info. I'll drive again this week and it shouldn't smoke since it wont have been sitting idle.
Rob
1980 911 SC
Old 10-29-2011, 09:47 PM
Mo money = mo parts
I wouldn't worry about smoke at start-up provided the motor isn't using much oil. If you can go 1,000 miles or more without adding a quart, then nothing to worry about.
Greg
86 Coupe (stock - pretty much like Butzi designed it) - gone, but not forgotten
65 Ducati Monza 250 & 66 Monza Junior (project)
"if you are lucky enough to own a Porsche, you are lucky enough"
Old 10-30-2011, 06:02 AM
80 911 SC, Orem, Ut
RSWiser's Avatar
Normally I can go about 1000 miles and only add 1/3 to 1/2 quart as long as it does not sit for a couple weeks.
Rob
1980 911 SC
Old 10-30-2011, 03:31 PM
