3.0 to 3.2L
Looking at a 3.0 that was bumped to 3.2L. Not interested in a modified case. I was told the crank is original. Could larger cylinders been fitted w/o boring the case?
Old 12-18-2012, 04:58 PM
Registered knucklehead
83-911SC cab's Avatar
Yes..do a search on a 3.2 SS (Short Stroke) on here...Bottom end (block, crank, rods) are stock 3.0 L size but the cylinders and pistons are 98 MM (as Opposed to stock 95 MM) giving the 3.2 L on a 3.0 L case.. 3.0 L rods and 3.2 L 84- 89 Carrera rods have different side rod ends and thus are different.. many on here have done this upgrade and I am thinking about it also..make sure to check all paper work for work done on engine in the conversion.. check the Engine Rebuilding thread also..
Enjoy,
Gregg S.
1983 911 SC Cabriolet, 1989 944 S2
1969 Chevelle SS396 w/427 Vette motor, 1970 Buick GS455
2000 BMW 528i Touring, 2005 GMC Sierra
Old 12-18-2012, 05:30 PM
Scott R's Avatar
Yes, it's very simple and a very inexpensive upgrade during a rebuild.
2021 Model Y
2005 Cayenne Turbo
2012 Panamera 4S
1980 911 SC
1999 996 Cab
Old 12-18-2012, 06:56 PM
