FranksPlace2's Avatar
Question The @#"<& knob is stuck!
I'm try to get the door panel off my '77 S to fix the door lock and I can't get that knob off the door lock. I tried liquid wrench and a "harness thingy" that I could pull. It broke.
Any suggestions???
Old 03-23-2002, 05:42 AM
cary's Avatar
Which one do you have ?
Pull up type on the top rail ?
Or dial type on the door panel ?
Cary
77 Carrera RS w/3.2 #59
73 914S 2.0 AG
73 914 1.7 Driver ( daily driver, under complete rustoration )
74 914 2.0, 71 914 Tub, 74 914 2.0 Tub + 73 914 donor
Old 03-23-2002, 08:10 AM
Team California
speeder's Avatar
'77 would have both knobs, (plunger on top and turn-type on door), top one unscrews and knob on door is screwed-on. There is a removable cap on center, (have to look close at it), pop that off and screw is underneath.
Denis
Old 03-23-2002, 11:20 AM
Cool
Thanks again, Denis. I'll check out that removale cap.
Frank
Old 03-24-2002, 02:50 PM
davis911s's Avatar
I hope I am not too late. But when you pop the cover off use a SMALL screwdriver (eyeglass type) and be gentle. Otherwise you will wreck it and need to buy new ones.
Shawn
Shawn
77 Targa with 2.7
My never-ending work in progress that has been off the road since Mar 2004
Old 03-24-2002, 06:27 PM
