-   -   Strange SC no start issue solved.... (http://forums.pelicanparts.com/porsche-911-technical-forum/637775-strange-sc-no-start-issue-solved.html)
G450X 11-01-2011 02:47 PM
After going through numerous threads and troubleshooting by the book, my non-factory type worn out key seemed to be the problem on my no start '82 SC.
I had (luckily) made a copy on an original type blank after I purchased the car. The new "copy" seems to have done the trick. If all else checks out on a no start issue, try the spare key!
pete3799 11-01-2011 04:46 PM
So your no start was not being able to turn the ignition switch (engage the starter) with the old key?
Or was the switch turning but not starting?
G450X 11-01-2011 05:05 PM
Most of the time the key would insert and turn, but was at times difficult to move and it would "click," but not turn the engine over. Every once in a while I would have to gently move the key a bit in or out to turn it and it would fire, or bump it back and forth - some times it just would not fire, only click.
I think at some point the key became worn enough to not properly engage the switch. I cleaned the grounds (batt/trans) and replaced the electrical portion of the switch, checked the voltage at the starter, but that's as far as I got before the replacement key was put into service and solved the issue.
