sportomatic oil change
hey i have an 81 sc sporto. 3.0L
i want to change the oil in the car... does anyone know how much oil it takes? do i follow normal procedures like a 5 speed manual. also is the oil in the sporto connected with the engine oil? THANKS IN ADVANCE |
If you have the owners manual..It should tell you. If not, call Pelican and ask.
15 year PCA member ![]() 1972 911 E Coupe - gone now 1987 Mazda RX-7 2+2 - still cooking Swift DB-1 FF & Swift DB-3 F2000 -not forgotten 1979 911SC 3.0 & 2000 Camaro |
i dont have the owners manual.. it's a bit hard to call pelican because i live in australia. haha
As I recall my 1974 sporto 911 motor oil went through the torque converter (that's why my engine oil would overheat at the track). I used to just change the oil as in a normal 911. Drain from both the oil tank and engine case, change the oil filter & refill. I think I would start with 8 quarts. I'd check the oil level once it was warmed up and idling. Top off as needed. You never really change all the oil because you can't drain the oil from the torque converter, oil cooler & associated lines.
-Rich- 1984 911 Track 1985 911 Track/Autocross |
| Tags |
| 911 , porsche , sportomatic |
