Twin Plug 3.2 Motor?
Hi all,
Is there a HOWTO on wiring two MSD 6AL's for a twin plug setup for the 3.2 Carrera motor which uses the BOSCH Motronic DME?
Can the trigger signal from the Motronic unit be wired to the two MSD units in parallel, or do I need to also buy an Andial Signal Splitter device?
Thanks for your advice.
Old 11-02-2011, 06:00 PM
Jeff Alton's Avatar
You need a splitter, either one home made or the Andial unit.
If you search there was thread a couple of years ago where a fellow built his own splitter.
Cheers
www.turn3autosport.com
Old 11-02-2011, 06:26 PM
Hmmm... may as well get a M&W Pro14R ignition unit which takes the Motronic trigger signal and drives two ignition coils. It's got a wiring diagram for a 964/993 twin distributor setup.
Neater than installing a splitter + dual MSD's + dual coils
Old 11-02-2011, 08:14 PM
Jeff Alton's Avatar
I am not familiar with that particular M&W part, but they do make excellent products!
Old 11-02-2011, 08:33 PM
Curious why you would want to use the MSDs AND the Motronic for ignition? Not even sure it's possible.
Old 11-02-2011, 08:40 PM
The Motronic DME triggers the aftermarket ignition system (MSD/Crane/M&W), which then fires aftermarket MSD/Crane coils.
I need the hotter spark because my motor is turbocharged and the OEM ignition system just isn't hot/strong enough under heavy load.
Old 11-02-2011, 08:44 PM
I have been Following this thread as I am interested in the same thing. How were able to determine this? As I may have the same issue.
Jeremy C.
Why's he calling me meat? I'm the one driving a Porsche. (Bull Durham)
----Nothing is far away in this car!---
-2001 996 Turbo
Old 11-03-2011, 04:07 AM
jcc911, if you are experiencing engine hesitation under boost and you have ruled out any vacuum leaks, then it's most likely ignition (e.g. the spark being blown out under load) and you need a stronger spark. This is a very common problem with aftermarket turbo conversions depending on what boost levels you run.
Old 11-03-2011, 01:27 PM
No, no hesitation. Only lag. Running a 7200 with 993 HEs so I should, in theory, spool quick but that is not the case. Some have said it is ignition related, so I thought maybe I was blowing out the spark but I am only running 0.5 bar.
Thanks.
Jeremy C.
-2001 996 Turbo
Old 11-03-2011, 03:01 PM
Very interesting. Thanks for the explanation. I've seen twin plug setups for CDI ignition and for Motronic, but never the two combined. Certainly seems to make sense given the need for hotter spark. Good luck!
Old 11-03-2011, 04:49 PM
Burn the fire.
Brando's Avatar
911TT33, I have the wiring diagram for MOTRONIC with MSD systems in my profile. You only need 1 MSD box but 2 coils (one for each distributor). Run a splitter from the Small Orange wire and Small Black wire to the Yellow & Black of each coil.
[x] Working | [_] Broken: 2017 Victory Octane
[x] Working | [_] Broken: 2005 Ram 1500 SLT w/5.7L Hemi
"Drive it like you stole it."
Old 11-03-2011, 04:53 PM
Jeff Alton's Avatar
I have not seen that diagram or application before, not alll togeher suprising.....
Have you run that or has anyone??
Old 11-03-2011, 05:34 PM
Burn the fire.
Brando's Avatar
Jeff,
I made that because others had asked me how to do it. I also thought about sending it to Mallory to include just for us 80's Motronic cars (BMWs and others have Bosch Motronic). I followed that same setup for my 3.2 Carrera. Been almost a year, no issues, runs strong.
Old 11-03-2011, 06:26 PM
Thanks for the info, Brando. I heard that firing two coils in parallel from the single MSD isn't recommended as the resulting spark energy will be halved.
The general consensus is to run two MSD's and one coil per MSD for maximum spark energy
So, I *think* the recommended way is:
Motronic => ANDIAL Splitter => Two MSD 6AL's => Two MSD Coils => Twin Distributor
Can someone please confirm?
The M&W Pro14R ignition unit apparently replaces the Andial Splitter and two MSD's like this:
Motronic => M&W Pro14R => Two MSD Coils = Twin Distributor
Seems like the M&W solution offers a neater solution.
Old 11-03-2011, 07:01 PM
Burn the fire.
Brando's Avatar
Mallory (Not the company named MSD) supports the idea that you can run efficiently 2 coils without loss. With their coil (P/N 3440) you will not see diminished spark. The Mallory Hyfire VIA/L MSD system is an all-digital, micro-processor controlled unit. I've run one box on single-plug and twin-plug setups before with no loss.
Old 11-03-2011, 07:33 PM
BURN-BROS's Avatar
You can run one analog MSD with two coils with no problems, but I am not sure about the digital 6AL. Has anyone tried it yet?
Aaron. F.S. 1965 Solex engine w carbs/cleaner
Burnham Performance
https://www.instagram.com/burnhamperformance/
Old 11-04-2011, 07:36 AM
LJ851's Avatar
Why couldn't you just use a twin tower coil triggered by motronic or a single MSD ?
Rotary engines use these and have large spark requirements and many sparks per revolution. (Stout Coil !)
Am i missing something?
Old 11-04-2011, 09:03 AM
