How to lift Porsche?
I am buying a non-running 1973 914 and see UTube videos with the engine removed.
Where are the lifting points and can someone help me with this process?
Old 11-05-2011, 08:03 AM
cdrik915's Avatar
Hi mate ,
Hope that helps.
LIGHTER = FASTER !!!
Old 11-05-2011, 08:19 AM
RETIRED
Joe Bob's Avatar
There are little donuts on the four corners as you can see from the illustration above.
If they aren't rusty it's the best place to put the pad of a floor jack.
2012 ML350 3.0 Turbo Diesel
Old 11-05-2011, 08:23 AM
ivangene's Avatar
I bought one of these and for me (low lifting) I love it!!!!
(no affiliation with seller, but man does some nice welding!!!)
Porsche 911 912 930 914 356 Jack Pad Plate Tool HD! | eBay
the warnings are - these CAN slip out if the angle is too great (high lifting)..they will fly off on test rides --- a "remove before test flight" label should be applied!!
I like it because it gets both wheels off the ground at once.....
Ed M
86' Coupe
Old 11-05-2011, 08:48 AM
Not sure the lift points on a 911 chassis diagram will be identical in a 914. Better confirm before bending something.
Sherwood
Old 11-05-2011, 08:59 AM
ivangene's Avatar
is that one of those times when reading ALL the words is important
Ed M
86' Coupe
Old 11-05-2011, 09:15 AM
Racer
winders's Avatar
Well, the subject did use the word "Porsche" so I can see how the poster from France could get confused. The 914 is a VW (VW-Porsche) in France afterall!
Scott
Old 11-05-2011, 09:24 AM
cdrik915's Avatar
Ok , i had not noticed that was a 914 question.
Sorry.
Old 11-05-2011, 09:40 AM
RETIRED
Joe Bob's Avatar
My answer was for 914 applications.....on my 911 I use the jackpad and then set jack stands under the rear torsion tubes and on the front the A arms.
No donuts on the four corners under a 911.
Old 11-05-2011, 09:45 AM
ivangene's Avatar
here we go.....
LOL
Ed M
86' Coupe
Old 11-05-2011, 09:54 AM
