-   -   Torque setting for lug nuts? (http://forums.pelicanparts.com/porsche-911-technical-forum/638323-torque-setting-lug-nuts.html)
mclmk8d 11-05-2011 10:23 AM
What are the torque settings of lug nuts? I did a search and found lots of interesting info, but none had the torque settings. This is for 16X7 and 16X8 Fuchs wheels.
Oh Haha 11-05-2011 10:25 AM
94 ft/ lbs
intakexhaust 11-05-2011 11:59 AM
Info is in the owners manual.
masraum 11-05-2011 12:06 PM
Where's the pic of that Lugnut torque T-shirt when you need it?
Mitch Leland 11-05-2011 12:22 PM
I just round it off at 90 ft.lbs... As you're probably aware it's better to crisscross the tightening patten, rather than just tighten in a CW or CCW pattern. A dab of anti seize is also recommended.
DRACO A5OG 11-05-2011 12:25 PM
+1 = 94
mclmk8d 11-05-2011 12:48 PM
Thanks guys...I appreciate it.
@intakeexhaust: don't have the manual yet; the car is arriving tomorrow from PA.
GrantG 11-05-2011 12:51 PM
I was under the impression that it's 96ft-lbs or 130Nm for all Porsches (aside from center-locks).
Steve@Rennsport 11-05-2011 12:54 PM
92-94 lbs-ft since 1967,...:)
Canada Kev 11-05-2011 01:13 PM
And those torque specs assume that the threads are lubricated, as Mitch suggested.
Bob Kontak 11-05-2011 01:15 PM
95.9 ft lbs based on 130 Nm
and/or
94 ft lbs based on 13 kpm
SC Tech Spec book.
RWebb 11-05-2011 01:15 PM
threads AND convex face of the lug nut should be lubricated with a thing smear on anti-sieze - P AG also specs a particular one...
Canada Kev 11-05-2011 01:20 PM
Yes, lube on all contact surfaces. I guess I should have been more specific. :)
