I was just outside, vacuuming the inside of my car, while the seat is out (in preparation for the testing Russ and I will be doing later, where we need access to the DME), and I discovered the DME relay is hot, just as it is after the car stalls. What's interesting is the face the car is not turned on, and the key is not in the ignition.
Is this normal? |
I did not read this whole thread, but FWIW, I've seen 4 or 5 different cars that strangely cut out at different rpms as if the rpm limiter was kicking in early. It did not happen until the engine warmed up. In each of these cases it was traced down to bad injectors. On the dyno, the air fuel ratios get very erratic and inconsistent from run to run, and the engine would buck randomly or rev limit at 5000 or 6000 rpm. I don't know if this would be your problem as the bad injectors in these cases cause bucking and cutouts, but not for the engine to shut down.
Old and faulty injectors get sticky or have difficulty switching in a controlled manner at the extreme ends of their duty cycle, such as at a high rpm full throttle range where the injectors are called to pulse open >90% or at a very low duty cycle such as revving with no load on the motor at >4000 rpm where the injectors are called to barely switch open at a high speed at a <3% duty cycle. When they get heat soaked their coil resistance rises further which would make an already marginal injector harder for the DME to control. |
But I doubt this is the main problem. |
You can slide back the relay a little ways to expose pins. If I'm not mistaking, only one pin should have power. If more than one, I wonder if your ignition switch is staying on when turned to off?
That would explain hot relay and power to injectors. |
Greetings folks,
We just finished for the night. Russ, Mark and I first attacked the issue of the DME relay and DME always being on. It turns out there was a short in the DME relay connector, which caused this issue. Once we identified the issue, we fixed the short, tested it, and put it back together, all is fine there. Then we took the car out for a test drive. The car died as usual, thus we began our testing. Note, we did not hook up the Oscilloscope yet, that will happen tomorrow night. When the car died, we checked power at the injectors and fuel pump - the volts were fine in both spots. Then, for some strange reason, while the car was dead and wouldn't start, we pulled the connector off the middle fuel injector on the drivers side. The car started right up. Then when we re-connected it, the car died and would not start. Then we tried that same test again, this time pulling the connector off the injector closed to the rear bumper, still on the drivers side. The car started right up, then when we reconnected it, the car died and would not start. Thus after the car died, we were able to start the car on five injectors plugged in and it died when we attempted to re-connect the sixth injector. Of course, after a bit of time, the car restarted with all six injectors connected. I'm not sure if this leads us to bad injectors, but it may. We plan to test the injectors tomorrow night with the o-scope. Any and all thoughts are welcome. More to come soon. Thanks for the suggestions and hanging in there. Scott |
More details to follow Scott's post (and a few corrections):
First, we solved the problem of the voltage on the injectors with the key off. Turns out there was a short between the DME relay terminal 30 wire and the terminal 86 wire in the DME relay socket. This meant that the DME power relay was always on and the DME CU was always powered. We couldn't see it but the wires tested as shorted and removing all the wires from the socket and carefully reinserting them resolved the short. We may revisit that one because it may cause problems in the future. We also found that the black wire on DME relay terminal 86 was wired to the wrong fuse position so we fixed that though the short masked the effect. So we have all that wiring back to as it should be (the wiring harness that goes between the engine, the DME CU and the fuse panel has all be replaced so that may explain why these issues have cropped up). We also did some road tests but didn't get a chance to open the DME CU and put the scope on anything. However this is what we found in the road test (all done after fixing the DME relay wiring): 1. We tried slowly accelerating the engine to 5000 RPM in first and second and it didn't die. Then we shifted to 3rd and jumped on it and it died. 2. When the car dies the power on pin 87 of the DME relay is constant, it doesn't cut out. So this means that the injectors have power and the DME CU has power. 3. When the car dies, the power to the fuel pump is constant, it doesn't cut out until the engine stops turning and then the DME CU shuts it off. 4. When the car dies and won't start, the coil has 12v. The fuel pump has power while we are cranking the engine, the injectors have power (e.g. there is power on DME 87) and yet the car won't start. 5. The injectors each tested as 2.7~2.8 ohms when cold. After the car died we tested the middle injector on the driver side and it was 2.7 ohms. Then something weird happened. We pulled off one of the injector connectors to measure the voltage to ground while cranking the car and the car started on 5 injectors. With the engine running we plugged the harness back on the injector (the middle one on the driver's side) and the engine quit and wouldn't start. We then unplugged that one injector and it started. We then shut the engine off, reconnected the injector and it wouldn't start. Unplugged it again and it started. Then we plugged it back in and it wouldn't start. Then we unplugged the front one on the driver's side and the engine started. Shut down reconnect and it wouldn't start. Unplugged again and it started. So the car would start if 5 injectors were connected but not 6. We discussed this for a while, 5 min or so, reconnected the injector, and then it started on all 6 injectors and we drove it home. So, just after it has died, it has power to the coil, power to the fuel pump, power to the injectors, but it won't start with 6 injectors but it will start with 5. The injector harness in the engine compartment has been replaced. The harness from the fuse panel to the DME CU to the engine has been replaced with a used harness. This means that all the wire between the DME CU and the injectors has been replaced. The grounds have all be cleaned up and redone. Steve Wong has checked out the DME CU as good and other DME CUs have been run in the car with the same engine cut off effect. So could there be a condition with these 6 injectors that appears under load, disappears with time, or disappears if one injector is disconnected? By the way, with 5 injectors connected to the harness we measured the resistance between the pins on the 6th injector harness connector and got about 0.8 ohms. This is in the neighborhood of what we would expect for 5 2.7 ohm loads in parallel. So there isn't an obvious short. Next up, put a scope on pin 14 or 15 (injector signal) of the DME CU and see how the signal looks and what it looks like when it dies. Our hypothesis is that when it dies, and when it won't start, there are no pulses or at least no good pulses on pins 14/15. Russ |
It's acting like one injector is shorting.
Removal of any one of the injectors may be enough to raise the total R enough to permit the driver to work. You need to measure the Resistance of each injector before and after it dies. Or swap them all. Scoping now may not help, as the driver is common to all, and there'd be nothing to measure anyway when the driver is off (in fault mode). Nice job on the relay. |
As all six injectors are wired in parallel to the DME, if the overall impedance of the six injectors exceeds a certain threshold, the DME will not fire the injectors, and you will either get a no start or shut off condition. This can happen if the impedance of one of the injectors rises just enough so that the net impedance rises above this threshold. For example, the net impedance of six 3.2 injectors at 2.7 ohms each wired in parallel is 0.45 ohms. If just one of the injectors when hot were to jump to 7 ohms or higher, the net impedance of the six parallel injectors adds up to 0.50 ohm, enough for the DME to shut off the injectors.
Steve - we are looking for a rise in injector resistance? I thought we would be looking for a drop, which would draw more current, which would overheat the output stage of the circuitry driving pins 14 and 15 of the DME.
Rick or Steve,
Looking at Rick's explanation here: http://forums.pelicanparts.com/3868545-post194.html is there some part of this circuit that would "overheat" or shut down under some overload condition? When the engine won't start, should we expect to see flat line on DME CU pins 14/15 but something interesting on pin 1 of that IC, in other words, its sending pulses but the output section is hosed? Or does the whole IC shut down? Maybe that's pointless. Other than changing all 6 injectors, what would be a solid test for an injector who's impedance is going bad? A changing ohms measurement between pins 14/15 and ground? We get a baseline when the car is cold and then another measurement right after the engine dies? We can't measure the 6 individual injectors all that quickly so I am thinking of a test done from the harness inside the car. Russ |
Did the thread say you tried multiple DMEs and they all did the same thing? I wouldn't suspect the DME.
Why not just call Motorman (see the above thread) and get 6 new injectors. The ones I have are not the same part # as what was in there but they flow the same and work great. He has used tested ones for $30 each (do all 6 this route = $180??). New are $45 EDIT If you look at that peak and hold driver data sheet link you can get a better idea of what the DME is trying to do and how if the impedance went down it would screw it up. EDIT AGAIN: Here is the link. Start reading application information on page 5. http://www.st.com/internet/com/TECHNICAL_RESOURCES/TECHNICAL_LITERATURE/DATASHEET/CD00000086.pdf |
Rick-I,
Regarding the DME's, I have tried 2 other DME's (all known to be good) and both gave the same results. After that, I sent my DME to Steve Wong for a bench test and repair, he then installed my DME in one of his 911's and drove it successfully for 20 "spirited" miles as he put it, and it performed well. I spoke to Motorman yesterday, and talked to him about the injectors. He's currently out of the 364's (0280150364), which have the metal tip, but has the 360's (0280150360), which has the plastic tip. He states both work the same and does not agree with what one person stated in another post. I've been waiting til all tests are done, mainly due to the fact I've replaced quite a number of parts, in my attempt to resolve this problem. I'm all for ordering new/refurbished and tested injectors, I just want to make sure this solves my 11 month mystery. To date, I've done quite a bit of "preventive maintenance", which hasn't solved the problem. Tonight we will continue our tests using the o-scope, and post results later. Russ's question above about the injector resistance rising or lowering during the overheat condition is still of interest. Any thoughts? and thank you as always!! |
"This can happen if the impedance of one of the injectors rises just enough so that the net impedance rises above this threshold. For example, the net impedance of six 3.2 injectors at 2.7 ohms each wired in parallel is 0.45 ohms. If just one of the injectors when hot were to jump to 7 ohms or higher, the net impedance of the six parallel injectors adds up to 0.50 ohm, enough for the DME to shut off the injectors."
Actually this is totally incorrect. The total injector impedance needs to decrease to cause the injector driver stage to reach its limit current and thereby not provide enough current for all injectors to open properly. The problem occurring here can be caused by an intermittent fuel pressure regulator sticking at the higher pressure after a hard acceleration where the fuel demand is great compared to low RPMs & load. Therefore, the fuel pressure needs to be monitored to eliminate this as a possible problem. The excessive fuel will cause the engine to die as experienced. Bottom line: Let's not provide erroneous info and waste the car's owner time and money using the shotgun approach to troubleshooting as it appears as has happen in this thread! |
How does injector impedance decrease? Isn't it static to the coil?
Impedance and resistance are different things. The measured resistance of each injector is a function of how big the coil of wire is in the injector. The impedance is going to be a function of the *dynamic* signal being sent to the injector. As Rick explained in one of his other postings, when the DME CU first grounds the injectors and the current starts to flow, the rising current in the injector coil creates a magnetic field that pushes back on the current and slows the rise of current (I think that is how it works). This is called "back EMF" (EMF = electro magnetic field) and only occurs while the current is rising or falling. As well, the movement of the metal slug that controls the flow of fuel will further alter the magnetic field in the injector and the back EMF it causes. So I think this is all quite complex and if one of the injectors isn't working right, it may upset the performance of the circuit.
However, to produce the experience that we have of the engine just shutting off, it seems like the only possible failure is that the DME CU stops pulsing the injectors entirely. It flatlines. I can imagine that if too much current is drawn some thermal protection circuit in the Darlington transistor might cause it to shut down, or maybe the IC shuts down. Hence my question as to what we should look for in that output circuit. If the Darlington or T404 or whatever shuts down, does the IC know that? Does it keep pulsing? Russ |
I'm just going to provide a guess here now and electrically it is just a coil of wire.
I am thinking after 27 years a couple of coils may have vibrated together thinning the insulation and when it gets hot makes contact. Since that coil will have less inductance the DME sees the target peak current too soon and goes to hold mode before the injectors open. |
Many years ago I had a 911 stop running when it was given a meduim to full load on the engine. It turned out to be a restricted screen element in the fuel tank. It would run all day at light load and lower rpm, but not at full throttle. The best way is to either do a volume check thru the whole fuel system or take the screen out and inspect it. I don't know if this was mentioned before....there are alot of posts to read at this point.
Take the resistance measurements at each injector, not the harness, or use your mechanic friends spare parts.
While I'd never question SW, removing one injector be it good or bad is equivalent to increasing the resistance (and impedance for that matter). And when you did this, it worked. Quote:
A better question would be: "Would a shorted injector that equalizes the voltage across all injectors in parallel affect their operation?" Quote:
Send them out or substitution method. No Yes - at each injector. I would do what I could in the 15 minute window (and it sure sounds repeatable); and no, not at the harness. Quote:
Swapping is free. if it solves your problem, then send out your set. |
Go ahead and send 'em out to put that part to "bed"....
Doyle |
I will once again offer to send you 6 injectors that were removed from my 1984 engine when I upgraded to ITBs. I can also include a working motronics unit and DME relay along with a fully functional distributor. In essence the entire control system minus the coil. If you really want to go for it I will send along very nice intake control box. If you can't make it run with that then clean the dang grounds. If you find a part you can use either buy mine, send mine back and get a new one or get one from someone else. I don't care as long as you send my stuff back once the car is running. No need to spend a bunch of money just to test a part.
Scott:
First, sorry to hear of your problem with your car stalling like this. Second, I am no expert but this sure does sound like a problem I had with my 1987 944n/a since they share some of the same Motronic components. In my case, when I installed the new TPS (Throttle Position Switch) I did not set it up correctly for FOT (Full Open Throttle) so it did exactly what you're describing here stalling/cutting out at 3000RPM. However, with that said it appears that has been looked into. The other thing that comes to mind, when these types of "hair-pulling" problems that just don't seem to get resolved happen, is: Is it possible this car was exposed to water or salt water that got into the wiring in the tunnel? It seems to me that these types of problems appear after the wiring begins to corrode. Anyway, hope this helps. |
This procedure is worth doing just on general principles. You can also have a Very competent electronics shop with STRONG magnifier reflow solder joints especially around the transistor. When you button it up- mount the DME on a thin sponge to absorb some of the vibration. |
Greetings All,
Dfink, I do appreciate your generous offer to let me try your injectors and DME. Since I had my DME fixed by Steve Wong, who placed it in one of his 911's afterwards, I believe it to be good. Also, I did try two other known good DME's and countless relays, all of which have tested out to be good. As for the injectors themselves, after last nights tests using an oscilloscope, we're pretty confident the injectors are indeed the problem, thus I'm going to order a set today from MotorMan (a guy who many folks on this forum have recommended). I'm not sure if you saw this on earlier threads, but my mechanic has a stock-pile of new-old, new and known working used parts, thus he's tried many of the parts I've mentioned (temporarily) just to see if the problem went away. In reality, the only parts I've replaced on a permanent basis are the sensors, fuel pump, and the harnesses (because we smoked my wiring harness during tests). The WOT switch and throttle body were replaced when I installed a Steve Wong chip, about 18 months before this issue started, thus to TibetanT's comment, which I appreciate, that is probably not the issue. Over the past few days, we've done some pretty good testing on this area of the car/engine, and if you think about it, from the DME to the Injectors, there's not much in between. Since we know the engine harness is good, and we know the fuel injector harness is good, and we know the DME is good, what's left? Blackie911, I like the idea of the thin sponge and will try that. TibetanT, There's no evidence the car was exposed to water at any point, as there's no rust or corrosion any where on the car. Also, this is the third wiring harness in the car, so it's tough to believe they'd all have issues, but we did check this one out thoroughly. Also, since the car is 27 years old, it may be ready for new fuel injectors. Of course, I've been saying that about everything else we've tried to date... :O Thanks again for the input and suggestions, I'll let you know what happens after I install the new injectors. |
Damn... No scope photos....:)
I have a similar issue with my 87 targa; the former owner is a good friend and confirms the issue has been with the car for the 16 yrs that he owned the car.
The issue is a hesitation that occurs approximately 5 minutes into driving, it lasts for ~30-60 seconds (seems like 15 minutes when you're traveling on a highway), primarily when the car has sat idle for an extended period. The car really bogs down and seems to be starved for fuel; the odd thing is it will not stall, but it seems as though it will at any moment. :eek: The issue has been there with a stock DME and was not remedied with the addition of a performance chip, so it's obviously not a DME issue. Puzzling... |
What does the tach do while this is happening? MacGyver would rig a fuel pressure gauge he could watch inside the car. Injectors here would be a $200 gamble. |
Sorry - was busy with stuff. Here are the promissed scope shots. Negative lead to signal (pin 1 for ignition, pin 14 or 15 for injector) and positive lead to B+ (pin 18) on the DME.
http://forums.pelicanparts.com/uploa...1345234159.jpg Ignition coil: DME turns on (red). The coil "sees" full +12V for about 4 milliseconds of dwell time. Then (green) the voltage across the coil is reduced to 5 volts reducing the current while holding the magnetic field. At (blue) the coil is turned off and the collapsing magnetic field induces a voltage spark that gets transformed to release a spark. http://forums.pelicanparts.com/uploa...1345234191.jpg http://forums.pelicanparts.com/uploa...1345234221.jpg Two shots with different time base of the injector. Yoy can see the peak&hold pattern: At (red) the DME turns the injector on with full +12V for 200 usec. in "peak " mode. This is to shock the injector open. Then after a short duration the injector is kept open in "hold" mode for a total duration of 1.7 milliseconds. The "hold" mode beginning at (blue) and ending at (orange) is a modulated voltage. The injector sees an average current that is equivalent to the duty cycle. This is called PWM (pulse width modulation) and is a common way of controlling currents throgh inertal electrical devices. The current is monitored and the duty cycle adjusted accordingly. At the end of the injection the magnetic field collapses and induces a spike into the negative that has to be handled by the DME. Let me know if these help and what comes out of testing. Ingo |
"Injectors here would be a $200 gamble."
That's exactly it! The likelihood that all 6 injectors have coil shorting problems is very low. And if that were the case, only buying new ones would solve the problem, as any "rebuilding" (basically a cleaning) would not resolve an intermittent coil shorting. Again, this thread leads to another shotgun troubleshooting effort as is usual! If it's thought that some injectors may be shorting, then selectively remove pairs of injectors and then duplicate the failure mode. Also, use a noid in the place one injector to easily determine if the injector drive signal is still occurring. Again, monitor the fuel pressure to eliminate a possible bad fuel pressure regulator! |
Thanks for the scope photos. I've never had the need to look at the fuel injector waveforms so hadn't really verified what they were. Now if only you had a DC current probe.... just kidding.
You should point out that if he doesn't have a fancy scope meter and and looks at the signal referenced to chassis he will see the inverse of those (or at least 12-those) Why are OEM injectors for this car $426 each? If you are going with the generic (different part #) Bosch injectors I would definitely do all 6. With all these intermittent stories that are springing up I am nervous about my reconditioned ones. |
Greetings,
I ordered injectors from MotorMan today, they are Bosch reconditioned injectors, and came in a bit over $200 for the 6. So yes, I'm taking a gamble, which I hope pays off. They come with a one year warranty, so only time will tell. As for Otto's comment, we have checked the fuel pressure and it was between 35 - 40 lbs, which I'm told is correct. Last night, we hooked up an O-scope to the injectors and when the car died, the injectors flat-lined. Also, removing one injector allowed the car to restart, but upon reconnection, the engine died. If we consider the flow from the DME thru the wiring harness thru the engine connector thru the fuel injector harness to the injectors, the only thing that hasn't been replace and/or tested is the injectors. They should arrive next Tuesday, so hopefully a day or two later, I'll have more info to report. By the way, I have a video of the o-scope. Can someone tell me how to place it on the forum? Thanks. |
"we have checked the fuel pressure and it was between 35 - 40 lbs, which I'm told is correct."
Based on the unique failure mode, the fuel pressure test needs to be done as follows: 1. Connect the gauge PRIOR to the failure. 2. Leave the gauge connected. 3. At the time of the failure, immediately check the fuel pressure. Any test of the fuel pressure without the gauge always connected and NOT disconnected prior to the failure is meaningless to test for an intermittent high fuel pressure! |
Otto,
In your opinion, what would cause the fuel pressure failure? Thanks. |
Otto
There are two threads here. wnsgc and RPSTech are troubleshooting an 85 and bigel kind of hyjacked with an 87. |
What I am remembering about the injectors is they get a ground signal from the DME to fire? Or was that something else?
If so, I would wonder if the DME harness is not giving a good ground to the DME. On Steve's cars the harness is good and gives the DME a good ground to send, and that portion does not fail. If I am wrong, back to square one. See post 25 in this thread. http://forums.pelicanparts.com/porsche-911-technical-forum/659459-motronic-injector-signal-testing.html |
I think I calculated the current set point from that roll your own op amp (diff pair) for the ignition coil at 8 amps. |
Rick, not a lot of work at all. Here is what I do:
I insert a 0.1 Ohm resistor into the line between the injectors and the DME. I can measure the voltage drop across that 0.1 Ohm resistor. The current I through the resistor (and the injectors) causes a voltage drop U. Ohm's law gives me I=U/R. So I multiply the measured voltage drop by 10 (divide by 0.1) and that is the injector current. BTW, the shunt in the 3.2 DME for the injector happens to be 0.1 Ohm exactly..... |
| All times are GMT -8. The time now is 10:04 PM. |
